Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 02-12-2007, 09:42 AM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
How steep is too steep?
We have an opportunity to boondock this summer in a fabulous place in Colorado. Access is via a driveway that is 900' long. There are a couple of 100' intervals on this driveway that have a grade of 15-18% (maybe as much as 20%). No issues with turn radius or anything.
We have a 30' Classic (1999) towed by a 4x4 Ford F250 Diesel. We can go up/down as slowly as we want.
Questions:
1. assuming good road surface, any issues with this combination getting up a grade this steep? (the road is packed gravel, not asphalt, but its brand new)
2. any concerns about gray/black/fresh water tanks? Should they be emptied before going up/down? This is not just a weight issue - we don't want black water spilling out from the toilet seal!!!!
Thanks.
Here's our rig, and our destination!!!
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 02-12-2007, 09:46 AM   #2
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
Having traveled on some roads with slopes in the range you describe, traction will be your most critical issue. The worse condition would be loose gravel. If surfaces are firm and tight, no problems.
So Long!
Bob Thompson is offline   Reply With Quote
Old 02-12-2007, 10:04 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Do you have Enkay Rock Tamers mounted on your hitch to cut down throwing gravel? They're a good idea for all around use.
5 meter Langford Nahanni
Old 02-12-2007, 10:10 AM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Cann't imagine you don't have the power if your traction hold.
I am wondering in such a situation which would give you more tractions.
1) No WD, let the full weight go to the rear wheels and use 2 wheel drive.
or
2) WD with 4 wheel drive.
How is your truck setup. If one of the rear wheels spins are you dead in the water or will the other still have traction?
Over59 is offline   Reply With Quote
Old 02-12-2007, 10:18 AM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Loss of traction would be a big problem. If the truck slides you may not be able to stop. going backwards. I would try the truck only first.
Do you have limited slip rear end?
Michelle TAC MT-0
Sarah, Snowball
Old 02-12-2007, 10:51 AM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Give 'er hell and keep the 4wd on.
Ditto the mudflap comments....
I think you'd be fine. Loose gravel, ok, as long as you don't loose momentum. It's not the safest thing to do, but going by the photos, it doesn't look **that** bad....then again, looks can be deceiving.....
Old 02-12-2007, 11:06 AM   #7
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
limited slip
we have limited slip, and have already been up the driveway in the contractor's F250. Even a 2-wheel drive would be fine without a trailer. We're just worried about 'spilling' stuff and whether this is just too steep. I know the Ford has the power!
Oh yeah - yes we have Enkay's.
Old 02-12-2007, 11:39 AM   #8
1960 22' Safari
in the wilderness , The great Mojave Desert
I don't see a problem.
4Wd at a slowish constant speed and you're there. Don't stop until you reach the top.
Airstreams handle really well off pavement. Even in deep sand. So don't worry.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 02-12-2007, 11:48 AM   #9
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
With a good surface, I wouldn't worry about going up.
Going down, however, may just scare the bejeesus out of you.
pmclemore is offline   Reply With Quote
Old 02-12-2007, 12:01 PM   #10
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
20% grade is "very" steep.
Compare highway grades at 6 to 8% and they can be tough to pull a heavy trailer up and on the down side they have run outs for runaway trucks.
I doubt 2 wheel drive would climb a 20 deg slope unless paved.
Garry
Old 02-12-2007, 12:01 PM   #11
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Others have touched on my thoughts:
1. On the uphill don't stop or you could find yourself in the position of not being able to go up and loosing control on the way down backwards.
2. On the way down you will have the trailer pushing you and you could loose control. Go as slow as possible.
3. This may be overkill but I guess you could rig a block and tackle or use wheel blocks for the way down. Are you a sailor, got a spare anchor?
Old 02-12-2007, 12:05 PM   #12
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
other trucks
I should have mentioned that construction trucks will use this road, and it was designed accordingly (big dump trucks, concrete trucks, etc.).
I should have refined my question more, but I think our biggest concern is simply the concept of 'tilting' the trailer that much. Sounds like we'll be OK.
Old 02-12-2007, 12:32 PM   #13
Images: 67
Once, my wife failed to turn the shower off at the faucet, which left a trickle at the shower head which she had turned off. We were hooked up to city water and the shower head trickled all night. In the morning, we had 2" of water standing in the shower. Aargh! Luckily, the dump station was about 50 yards away on a level road. It was a nice slow drive to it. It would have been disastrous to drive up or down any grade to get to a dump station.
So Long!
Old 02-12-2007, 12:51 PM   #14
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Another thing I would really watch is the weather. The weather here in the high country can change dramacticly from morning to evening. A road that was passable in the morning can turn into a nightmare with a little rain or snow mixed in. Alot of roads in the Colorado Mountains turn into creeks with very little rain. Be prepared to wait it out and let the roads dry before proceeding to your next distination.
Old 02-12-2007, 01:03 PM   #15
Full-timer
1971 27' Overlander
Pumpkintown , South Carolina
Over59 touched on the WD hitch issue, and this is one often overlooked in rough terrain. Negotiating a steep dip with a long trailer can cause the WD to lift the vehicle's wheels right off the surface, and less extreme articulation can certainly lessen rear traction.
It's not the heat, it's the stupidity.
Foureagles is offline   Reply With Quote
Glass replacement for Corning! Forrest Windows, Doors, Locks & Vents 104 11-26-2006 10:20 AM
Road passibility - Santa Fe to Breckenridge Zed2 On The Road... 10 04-21-2006 01:29 PM
Backing up steep driveway-wheels under rear bumper? Wexus Off Topic Forum 12 03-16-2006 08:15 AM
Steep Grades luckydc On The Road... 18 07-27-2004 01:51 PM
math wiz's: how steep a slope can I back up? Chuck Towing, Tow Vehicles & Hitches 12 05-05-2003 01:18 AM
