So after another week I got the shell back on!!
Redid the bearings, shackle bolts and U-bolts. Then I put down some MDO plywood on the frame (MDO is an exterior grade plywood with resin soaked fiber overlays between the veneer layers and on the surface) and secured it in place with ceramic coated screws that worked like a charm!
I had to come up with the radius on the ends myself by reading up on the treads and doing some math since my floor was practically non existent. I did have the original width of the flooring which was helpful, that was 85 1/4".
Then I cut out some new C-channel for connecting the shell to the frame and secured the down with Lexel caulking (instantly waterproof and sticks to anything) and screws until I get a chance to run the 1/4 bolts to the frame (I was working against the weather). I ran the laser on the frame to make sure I had it all straight the with a little bit of finagling, I was able to get the shell connected again and the wheel wells riveted back on as well.
I started patching up the windows with some temporary aluminum. I'll have to do most of them but we'll at least have two working windows and the roof vents. Also doing some small temporary patches where I had a few utility holes in the shell. I'm not to concerned with the random patches cause they will be coming out once I can rehab the windows. Also most of the bottom panels will need to be replaced, nbd!
This week I'll have the exterior done and the inside should be painted, getting close to the deadline but all you got to do is "prioritize and execute!!" I'll be taking this baby on its maiden voyage at the beginning of June, anything I'm missing??
The tail lights and marker lights are going in as well as the trailer wiring junction box, those just arrived.
I order new door hinges since I didn't have any on the trailer.
Safety chains and weight distribution has been ordered.
New rims and tires and being picked up this week.
I'm still trying to figure out the damn shocks for this thing though, anyone have any ideas? I also sheared off the mounting bolts the attached to the bottom of the leaf spring but am sure I have found the right replacement one, it comes in a kit from Monroe 33033 shock.
Thanks for looking, information always appreciated!! and keep in mind I'm just getting this road ready and weather proof, it'll be doing the full renovation once I'm in California and converting it to a tandem axle.
