Update on Macropoxy Paint
Just wanted to give people an update on the painting I did with Macropxy paint.
It has been about 3 years and is holding up very well. You have to work really hard to scratch it or **** it up. Again for whatever reason maybe i didn't thin the paint enough but it has a little texture to it so if you use this method I am not sure if it was the roller used or the thickness of the paint. If you want a smooth finish make sure to thin it even further than typically recommended.
I actually like the texture it is kind of cool and unique to it. It is hard to explain but will try to post a picture with a close up of the texture.
