Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 11-25-2013, 07:07 AM   #61
nowhere , Texas
if you have a couple rotten spots in your subfloor you should take off a full panel of subfloor. take a look at the insulation and for rust on your metal frames. i recently started a 79 argosy and i was suprised how disgusting it was under the floors.
for now i wouldnt spend money on a fridge and water heater, i would be looking at impact drivers, plywood, and insulation.
i used to live in SA, went to UTSA. Texas Argosies Unite ")
blackbetsy51 is offline   Reply With Quote
Old 11-25-2013, 07:11 AM   #62
nowhere , Texas
try to trace everything before you burn your old subfloor.. it sits in this metal frame that runs around the perimeter of the rig. it can be a pain to get that floor out. crowbar and hammer should do the trick. also crowbars work efficiently for getting out rivets, there are youtube videos out there that show you how to do it with a drill bit. good luck, don't forget your mask and goggles when starting to mess with that stuff under the subfloor
Old 11-25-2013, 08:46 AM   #63
DKB_SATX's Avatar
Alamo Heights , Texas
I lived in SA when I signed up for AIRForums. I should have known better than to put potentially-changing data in my ID (databases are my profession) but I wasn't thinking about work when I signed up. We've been in Fort Worth for years now!
Even if the subfloor had been perfect, the belly pan is far from it. A full replacement of the belly pan was already on the menu, and removal of all the insulation, replacing it with something waterproof like reflectix. In that process any frame issues will be addressed.
I've already bought a water heater but only because a very favorable deal presented itself. The refrigerator will be a very late purchase, sometime next year, when all the other structure and systems stuff is ready for a shakedown trip.
I'm farming out the subfloor work to Top because I want to get it done in a timely fashion and done properly the first time. I don't have enough time to devote to it and I don't have a great place to work on it. I'm doing the less-skilled disassembly and prep first so I'm not paying for all that.
— David
DKB_SATX is online now   Reply With Quote
Old 11-25-2013, 05:10 PM   #64
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
I blame that screwdriver! Probably was super-strong. Mere wood didn't stand a chance.
You're probably leaning this way, but I'd get the whole subfloor replaced. If this trailer's a keeper, then do it once and do it right.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 11-10-2014, 12:16 PM   #65
Vintage Kin
Fort Worth , Texas
Any update in past year?
Old 11-10-2014, 08:00 PM   #66
DKB_SATX's Avatar
I have done a lot of deconstruction and cleanup, and some planning... I'm waiting for a place in the shop for replacing axles, floor segments and the belly pan and a curved segment and pano window.
— David
restoration
