Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Argosy Trailers > All Argosy Trailers
Old 10-24-2007, 12:17 PM   #1
DreamStreamr
full-timer
DreamStreamr's Avatar
Profile:  All , North America
Images: 37
Add another Argosy 24
We pick up our 1979 Argosy 24T Monday morning. Really excited to see it 1st time. PO says includes all original documentation for the unit and the appliances and complete repair hx. We'll see.
Spent all lunchtime today reading Argosy threads, learning about vin decoding and Minuet differences. Will look fwd to sharing what we get and what we get into. Gonna be interesting.
How many Argosy 24Ts are in the Forum?
Jim N5RTG & Deb KI4OKI
full-timing in our CCD 25 blue streak
sometimes seen behind the magnificent 2500HD 8.1L/Allison 6spd "Fred"
visit us at http://dreamstreamr.com
DreamStreamr is offline   Reply With Quote
Old 10-24-2007, 03:28 PM   #2
highmark
highmark's Avatar
Profile:  1977 24' Argosy 24
Swan Lake , Montana
Count Me In!
Hi! Sounds like you have a fun project ahead. Will be anxious to see pictures as you work through your re-model. If by "24T" you mean "twin" - you can count me in. I have a 1977 24' with center twin beds, rear bath and front dinette. I am almost done with my re-do and hope you have as much fun as I have - only sad part....working on the Argosy is lots more fun than mowing the lawn, cleaning the house, doing dishes....you get the drift - nothing else seems to be important. Enjoy your new addition! Carol
highmark is offline   Reply With Quote
Old 10-24-2007, 04:14 PM   #3
DreamStreamr
full-timer
Images: 37
Carol,
We have the identical floorplan. Don't know if Minuet or not, will measure it Monday when we see it. Can't wait! Did you repaint the interior surfaces? Is it zolatone? (the flecked paint) Any shocking surprises?
Old 10-25-2007, 12:25 PM   #4
Moonshot
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
Thumbs up
Hello Jim,
You have the exact same year and model that I do! After owning a 63 Tradewind for a number of years I got very specific in what I wanted for my next Airstream and the Minuet 7.3 meter was at the top of my list.
The walls and ceilings are vinyl clad (sort of like wallpaper) over the aluminum and some have complained that sticky stuff "weeps" through. It hasn't on mine yet though. Various cleaners are recommended to handle this if you have the problem - POR 15 I think is one. My endcaps were likely Zolatone paint, but the PO painted over that with a gray to match the other interior walls. Not bad, but not original.
I think you'll enjoy this trailer. The narrow width and light weight makes it a breeze to tow. If you have any questions let me know, mine is supposedly fairly original too.
Scott
Moonshot is offline   Reply With Quote
Old 10-25-2007, 12:31 PM   #5
Moonshot
The Painted Pig
Moonshot's Avatar
Images: 14
By the way, as you might have guessed the Argosy 7.3 meter Minuet is a rare Airstream. An unsubstantiated rumor says only one 7.3 meter Minuet was sent to each Airstream dealer. Also, as far as I can tell these were only made for one year - 1979. I have come across about six other 7.3 Minuets over the years. I bought mine in 2003.
Scott
Old 10-25-2007, 03:07 PM   #6
bhayden
bhayden's Avatar
Profile:  1978 24' Argosy 24
Woodinville , Washington
Jim,
I'm confused (what's new ). Did you just buy a Minuet or the "standard" Argosy 24' with the twin bed floor plan? If I'm not mistaken all of the Minuets are single axle trailers and the Argosy 24' is a tandem axle.
-Bernie
owner of a nice Argosy 24D but wishing it was the rear door model
bhayden is offline   Reply With Quote
Old 10-25-2007, 03:53 PM   #7
highmark
highmark's Avatar
Swan Lake , Montana
Jim....My Argosy is not a Minuet, but the regular sized unit. I am not sure how many units have the front dinette, but I consider us lucky to have that floorplan. Did you get the wonderful Orange, Green or Gold interior? Mine is orange and I have been having lots of fun with making it bright and cheerful! As for the Walls - - My interior side walls and ceiling are vinyl bonded to the aluminum. They were in great condition so all I had to do was wash them down with a water based cleaner organic cleaner. The other interior walls - between the kitchen/bedroom and bedroom/bathroom were vinyl on thin plywood. The vinyl on these walls was falling off in places so I removed the vinyl with a heat gun; removed the sticky adhesive and then put up new vinyl wallpaper with heavy duty adhesive.....I think they turned out real nice. I picked a neutral, slightly textured wallpaper so it blended in with the existing walls and ceiling. I don't think I have any Zolotone in my TT. The inside end caps are ABS with what appears to be the color molded in (kind of yellow). My front end cap is starting a crack so at some time I will remove it and have it professionally repaired - repainted at the time too! Surprises??? The good ones were that the appliances all worked - only had to have the stove top, that was chrome with rust flakes, powder coated. I thought I could save the AC, but gave in and purchased a new low-profile Carrier from Family RV - great folks with great prices!!! I did have one spot in the wooden floor that had some water damage - by the water tank at the front of the TT. I was able to save the wood by using a product from Dr. Rot. I coated the whole floor at the same time since I had all the interior out. I also replaced the countertops in the kitchen with a retro style in tangerine - stepped it down a notch from the orange that was there. I will be anxious to follow your remodel from start to completion. What are your plans for changes, colors, etc???? Hope that you have as good of luck as I have had with my project.
P.S. I immediately put the rock guards on the front wrap window - way cheaper than replacing that window. Best of Luck - Carol
Old 10-25-2007, 04:25 PM   #8
bobfowler
bobfowler's Avatar
Profile:  1972 Argosy 20
2007 Base Camp
Middletown , New Jersey
Images: 14
Congrats on the new baby! We love our 20 footer (though she's undergoing surgery at the moment).
If you intend to paint the interior, we've found that Glidden Gripper primer covers the vinyl clad walls and plastic endcaps beautifully.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
bobfowler is offline   Reply With Quote
Old 10-30-2007, 02:12 PM   #9
DreamStreamr
full-timer
Images: 37
Yes, it's a 7.3 Minuet
We arrived safely home at 2200 hrs last night with our new baby, Snow White. She is a 1979 7.3 Minuet double axle front dinette twin beds well-used and a little abused. Has all original documentation including congrats letter from Argosy sales mgr, owners manual, owners guide, appliance documentation including for both replacement and original fridge, air conditioner, and water heater. Two tambour doors perfect, and the one in the sink cabinet is gone, replaced with two ugly particle core doors. I want to replace the tambour for this cabinet, the tracks look fine. Fridge replaced with a Dometic 4 cf, looks okay. Water heater shot, and it was only 10 years old. All original under-bed and under-dinette bin boxes intact. Bathroom seems okay. Flooring torn out and replaced with 3/8" pre-finished birch finish wood not particularly well-installed and conflicts with the under-bed compartment doors opening fully. Under dinette is 6" ceramic tile floor and some of same material in bathroom. I may replace the flooring entirely.
Walls and ceiling in great condition, no cracks, no gaps. Electrical system seems excellent, all works fine on battery at least. Armstrong air conditioner replaced a couple years ago with Carrier a/c-heat pump unit. Furnace looks okay. Don't know condition of plumbing, tanks, piping. Will leak test and sanitize. Outside body is almost perfect. Windows all operate wonderfully, so do two roof vents. Paint is excellent, and original 3-color stripe is intact. Has baby moon hubcaps, dented up and a little rough looking but cute. Awning needs fabric and mechanism repairs/replacement.
General Questions:
1. Anyone have a best idea on finding or making the tambour material to replace the approx 30"X32" one for the sink cabinet?
2. Would anyone want the curtain tracks from the bedroom? The lower one for each window has the sort of convection-proof shelf as part of the assembly.
3. Anyone want the under-bed storage tubs if we decide to switch them out?
4. Has anyone replaced the sink cabinet top? This one seems a poorly done replacement I will want to replace and would appreciate any good tips.
See next post --
Old 10-30-2007, 02:16 PM   #10
DreamStreamr
full-timer
Images: 37
Thanks for your first replies,
Carol,
can you guide me on the rock guard investigation? I have heard the replacement glass cost is heinously high, so I'm tempted to tape bubble wrap on these or something until I can get them covered. They look good now and I want to keep them, so . . .
Bernie,
we were also confused. It was advertised as an Argosy 22T but the VIN clearly showed it would be a 24T. We still didn't know it would be a Minuet until we saw the body width and the Minuet medallions on either exterior side. We are delighted. It is sooo small compared to our CCD 25.
Scott,
thanks for the info -- I suppose it may be obvious we had no idea what we were getting into and barely know now. We spent a part of this morning emptying out the cabinets of 4,000 wal-mart empty bags and miscellany, and removing two interesting frames from over each of the twin beds -- kid bunk beds? Cast wall brackets as pivots and straps to a pair heavy cleats on the ceiling for each shelf/bunk. We don't know. For now we removed them and are holding for disposition.
I wish we could take Snow White camping immediately, but testing gas system, inspecting electrical, replacing water heater and testing/sanitizing water system are first. Want to protect the front wrap-around glasses especially. Then . . .
Meanwhile I will get some pictures posted by next week and let you know. Thanks for your sharing ways and helpfulness.
Jim and Deb on behalf of
Snow White
Old 10-31-2007, 10:59 AM   #11
Moonshot
The Painted Pig
Moonshot's Avatar
Images: 14
Sounds like a great unit, Jim!
The PO of my unit apparently replaced the tambour door under the sink with two sliding doors made of painted thin plywood. Think bypass closet doors. Sorry, I don't have a picture. I didn't know these was once a tambour door! Thanks for sharing that.
Under the bed storage units seem to sell pretty well on ebay as they get damaged fairly easily. Before you do so, consider that you can take these in the house and load up your clothing in them then carry them back out to the camper like you would a laundry basket.
Mine doesn't have the bunk beds over the twins. That sounds like a neat feature that I bet someone would pay good money to have if you ever choose to sell those.
Enjoy!
Scott
Old 10-31-2007, 04:32 PM   #12
RF2
Profile:  1974 Argosy 22
Bronson , Florida
Just bought a 1974 Argosy 22' rear door. Have all the original papers, except the manual. This Argosy sold for $5500. new, has been setting for 10 yrs., so I have a lot of work to do but when it's done, I will have a jewel. If anyone knows where I can get a manual for this 22' rear door, it would be much appreciated. Thanks, RF2
RF2 is offline   Reply With Quote
Old 10-31-2007, 05:31 PM   #13
bhayden
bhayden's Avatar
Yeah, the bunk bed feature was an Airstream option. Not sure if it was still offered in '79 or they were owner installed. Either way it seems like it would be nice to have. I'd love to install a bunk arrangement over the double in our Argosy. Maybe even over the front if that could be made to work.
Didn't know they made tandem axle Minuets. That's very cool! One thing we really insisted on when shopping was a tandem axle set-up. Flats with a horse trailer have sold me on the value of tandem axles on a trailer.
More important than the track for the tambor under the kitchen counter is the drum into which the door rolls up. However, you shouldn't have too much trouble finding one if your's is go because most people just give up on this arrangement. The overhead roll-up arrangement seems to be OK for tambor doors but the horizontal slide seems to be too problematic to bother with. Looks cool but just doesn't seem to work reliably.
-Bernie
Old 10-31-2007, 07:25 PM   #14
aturner4u
LookingThroughALens
aturner4u's Avatar
Profile:  1976 Argosy 24
Marietta , Georgia
Images: 20
Congrats on the new addition to your family.
Originally Posted by bhayden
More important than the track for the tambor under the kitchen counter is the drum into which the door rolls up. However, you shouldn't have too much trouble finding one if your's is go because most people just give up on this arrangement. -Bernie
Our PO also took out the tambor under the sink and put in some kind of sliding doors that catch your fingers WAY too often. We haven't decided what to replace them with but they HAVE to go.
In nature, light creates the color. In the picture, color creates the light. --- Hans Hofmann
Let's Rally!
January: Can Opener, Topsail State Park, FL
aturner4u is offline   Reply With Quote
trying to post a add to sell my Argosy SpiritLady For Sale & Wanted 1 12-03-2004 03:39 PM
add AC? AV8 Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-12-2003 05:01 PM
Saw add for 60 Safari Ajrandzin For Sale & Wanted 0 07-01-2003 11:25 AM
Dinette - would like to add Diesel Dude Cabinets, Counter Tops & Furnishings 2 08-07-2002 06:08 AM
