Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 09-21-2008, 09:57 AM   #1
mtbob's Avatar
1975 31' Sovereign
Billings , Montana
Uprading Towing Unit
Now towing a 75 Soverign (7000 GVW) with a 89 Suburban. It's a 3/4 ton 2500 with a 454 and 4:10 rearend. Looking to upgrade to a 96 with a 6.0. Does the new 6.0 have enough grunt for the mountains of Montana and Colorado with a 3/4 ton 2500 Suburban and 4:10 rearend ? Your sage advice and experience will be greatly appreciated.
mtbob
mtbob is offline   Reply With Quote
Old 09-21-2008, 10:06 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
In terms of gas engines, I don't think GM came out with the 6.0L until the 1999 or maybe 2000 pickup model year....I think the Suburban followed shortly thereafter. I have an '04 with the 6.0L and 4.10s and find it to do the job just fine. If I were knowingly going into mountains regularly, I might seriously consider the 8.1L-- just for the added power.
Old 09-21-2008, 11:21 AM   #3
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Subs.
I just moved up from a 01 6.0/3.73 to a 03 8.1/4.10, and wow what a difference. My 01 did great on flat land in tow mode, yeilding about 11mpg, however on any grades it was working it a bit with my Safari 30. Nothing terrible, never got hot or seemed to over work it however. I found a very low mile 8.1 liter and it does not even work to tow the airstream. As a matter of fact the tow haul mode is almost gears me down too much, slowing shifts. I am still getting the same or just a little less mileage and I am really satisfied with the new drivetrain.
Truck alone mileage is not a big deal as it is only a tow vehicle. I did get 14 driving back from Florida to pick it up and my old 01 can get as high a 16 truck alone.
I think in 96 they had a 350 and a 454 (5.7 - 7.4 liters)
SafariSS is offline   Reply With Quote
Old 09-21-2008, 01:23 PM   #4
mustang's Avatar
1999 27' Safari
Kent , Ohio
Hello. I am towing with a 5.4 liter gas engine. 6speed automatic tranny and 4:10 gearing. What a dream.
Your 6 liter should have plenty of power. Make sure it has 3:73 gears or steeper. 3:55 may not be enough.
The bigger the engine owe ya it will tow better.
I tow a 31 foot soveriegn and a 12000 lbs race trailer. No problem with my set up ( not at the same time)
mustang is offline   Reply With Quote
Old 02-06-2009, 08:16 PM   #5
86Scotty's Avatar
1973 31' Sovereign
Maryville , Tennessee
I may be a little late on this post, but i just bought an 02 chevy 6.0 to tow my 73 Sovereign and it's a beast of an engine. The 8.1 is better i'm sure, but upgrading from a 350 95 model, i can't believe the power and smoothness of this truck while towing. Most have a FACTORY trans temp guage too, which i find quite nice to have. Something about a factory guage vs. aftermarket gives me more confidence, but i might be too picky.
enjoy your new truck!
86Scotty is offline   Reply With Quote
Old 02-07-2009, 06:55 AM   #6
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
I would also recommend the 8.1 in the newer chevys 6.0 is a good build too. 5.3 is weak 4.8 is out of the question. If you are looking at a 96 as your post says they only offered 5.7 350 and 7.4 454 till 99 when the 4.8 5.3 6.0 8.1 replaced the old tech....
shermantic is offline   Reply With Quote
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
A/C Unit for 65 GT muddy_hollow Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-23-2006 02:34 PM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
