Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1974 - 1979 Sovereign
Old 11-05-2013, 01:23 PM   #1
Moak's Avatar
1977 31' Sovereign
Hanford , Ca
Drain fresh water tank
His trailer has been sitting for many years. If the sensors are correct then it still have water in the tank. I want to drain the tank but can't figure out where the drain valve is
Moak is offline   Reply With Quote
Old 11-05-2013, 01:42 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Probably on the curb side, between the wheels, sticking out of the side of the galvanized box that encloses the tank. You have to lie face down in the mud in front of the wheels, put your head slightly under the trailer, and look back between the wheel and the tank enclosure. Use a flashlight. Should be a little valve there.
Old 11-05-2013, 01:42 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Some of that model do not have a drain. Connect a battery to the water pump and run it till it is dry.
Old 11-05-2013, 01:46 PM   #4
1972 25' Tradewind
McHenry County , Illinois
Most trailers of that era have the fresh water tank drain valve under the floor close to where the 1 1/2 inch pipe from the outside filler hatch enters the tank. Look for a cut out on the floor in the cabinet on the wall adjacent to the filler. There are probably water line drain valves down there as well. Look for the valve on the pipe that goes through the floor and belly pan.
Tom
Tom Nugler is offline   Reply With Quote
Old 11-05-2013, 03:29 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is the tank above or below the floor?
Location of tank?
Old 11-05-2013, 04:34 PM   #6
Moak's Avatar
1977 31' Sovereign
Hanford , Ca
Originally Posted by TG Twinkie View Post
Is the tank above or below the floor? Location of tank?
I found a heavy metal plate bolted center of rig just forward of the wheels. I think this is the tank, could see three electrical connections.
ID:	199379   Click image for larger version
Old 11-05-2013, 05:42 PM   #7
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
The 1977 Sovereign 31' does not have a fresh-water drain.
We drain them by running a faucet and draining the water through the gray-water tank and out the gray-water dump valve.
Follow instructions provided on these forums for cleaning fresh-water holding tank with a sodium hypochlorite solution.
Ken L
2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
