Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Sovereign > 1970 - 1973 Sovereign
Old 10-27-2018, 04:23 PM   #1
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The last remodel
Over the past six years or so I have been working on my old Airstream after a 120 day gut and refit. I had a deadline so I did it “get it ready to camp” quick while taking care of the major stuff.
The first time out I used a lot of off the shelf stuff in my kitchen. I redid the drivers side kitchen a couple of years ago ditching the prefab crap, and now I just finished doing the same on the passenger side.
At the same time I relocated my batteries, inverter, charger, and my 120V control panel.
Do you think it was worth the effort?
(The second picture is the before)
(Edit- FWIW I wasn’t supposed to post the picture of the dirty water in the sink..... ) lol
Old 10-27-2018, 06:55 PM   #2
2015 25' FB Flying Cloud
Eugene , Oregon
Wow! So pretty!
Meeks is offline   Reply With Quote
Old 10-27-2018, 07:33 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Very special Airstream indeed. I like it. What a big difference between your hand crafted Sovereign and my original Airstream Overlander. My interior is fabricated from aluminum extrusions, plastics, melamine plywood, and tambor doors. Hey, at least it is light weight materials.
David
WBCCI #8607 VAC Region 11
KnowledgeBase trailer renovation threads: 69 Globetrotter, 76 Sovereign, 75 Overlander, 66 Trade Wind Such fun !
Old 10-27-2018, 09:03 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
David
Thank you!
Yeah, it’s heavier than stock, but still probably lighter than a new 30.
Old 10-27-2018, 09:05 PM   #5
2007 22' International CCD
It looks stunning! Great job!
Old 10-28-2018, 12:12 AM   #6
1980 24' Caravelle
vallejo , California
that is one great looking AS. love the wood. kurt
ke6gkv is offline   Reply With Quote
Old 11-20-2018, 06:34 PM   #7
NBC
NBC's Avatar
1971 31' Sovereign
Lubbock , Texas
Looks nice and cozy! Love the wood look. ��
NBC is offline   Reply With Quote
Old 11-20-2018, 07:23 PM   #8
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Really nice. I like it, especially the woodwork!
What is that HVAC unit below the TV?
Alan
Old 11-21-2018, 12:02 AM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Thank You!!
That’s a direct vent wall furnace under the TV.
Old 11-21-2018, 01:15 PM   #10
Sag Harbor , New York
Looks great!
Are your axles and shocks original, and have you weighed the trailer since the work was completed? Any concerns that you have added too much weight? All that plywood/particleboard really adds up.
What tires are you running [vs. the new gross weight]?
Thanks for any details, including the countertop, and sink [Corian?], material. It looks like real wood in the photos.
Have a great Thanksgiving!
Peter
Old 11-21-2018, 02:38 PM   #11
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Well, I did change the axles, I should have bought 3,500 pound axles instead of 3,000 pounders, but all and all they work fine, the trailer rides soft enough that the suspension can’t be bottoming out very often.
The last time I weighed it weighed 7880 pounds with 1,100 of that on the tongue “wet” and ready to camp. When stock, Airstream claimed an empty weight of 4,900 lbs.
I’ve made some changes since that WILL lighten the tongue a couple hundred pounds and hopefully keep the weight on the axles the same or maybe a little less.
I’m on my third set of tires, the first set were trailer tires, the last to sets are/were LT tires both load range C with a max load of 2,000 lbs a tire. I wore out the first two sets with no tire trouble.
The entire interior is sheeted in 1/4” plywood, the cabinets are constructed from 3/4” plywood ripped into 2” wide strips. The cabinet doors are 1/2” ply.
The countertop is made from 3/4” pine boards laminated to a piece of 3/4” plywood.
I’ve never had any weight related issues in the nearly six years we’ve used the tar out of the trailer.
Old 11-21-2018, 02:45 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The last remodel
I will have to admit to making the back of the trailer too heavy on the initial build, which initiated my first re-re model after my first outing. [emoji4] After that I was more careful of a little weight here and a little weight there.... it adds up....
Old 11-21-2018, 04:33 PM   #13
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Congrats on a beautiful trailer.[emoji41]
I've often wondered if the Airstream/Airforums community has a fond term for "creeping additional weight".
I just know that initially, most people have great intentions to reduce or keep track of weight; only to loose it as the project nears completion.......too worn out to care.[emoji3]
Cheers
Sidekick Tony
Old 11-21-2018, 05:10 PM   #14
Thanks for the updates JM.
Old 11-21-2018, 05:37 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
The last remodel
Right now..... Click image for larger version
At Last - At Last pt1949 General Interior Topics 9 02-03-2014 10:40 PM
Some pics of our remodel. Streamin 65 Interior Restoration Forum 19 05-30-2006 11:43 PM
Argosy 28' remodel rodkerns Argosy Motorhomes 5 04-19-2005 02:47 PM
Interior Remodel Finished (I think) SilverStreaker General Interior Topics 9 05-30-2004 05:22 PM
Kichen remodel - 85 Sovereign 25' j54mark Cabinets, Counter Tops & Furnishings 6 10-14-2003 06:20 AM
