Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents
Old 08-26-2013, 12:05 AM   #1
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Help.... popped rivets?
Hey everyone,
I just bought my 06 19' Bambi in June and have only had it out on a couple local trips and was planning a trip to the Grand Tetons, Yellowstone etc. and low and behold today when I was looking things over I noticed 3 popped rivets inside along and above the top hinge side of the door and in succession. I've had issues with the top hinge pin working loose and door not closing smoothly. I use a wd hitch and I don't believe it is too tight.
Does anyone know what could be the cause and can the rivets be replaced easily? living in San Diego I'm now wondering if a trip of this length might be a bit much for a first timer. I just bought a Yamaha 2400 generator and was looking fwd to a 2 1/2 week journey. Any ideas or help is so appreciated!
To all that respond, my thanks,
Mark and Laurie
Markj55 is offline   Reply With Quote
Old 08-26-2013, 12:52 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by Markj55 View Post
Hey everyone,
Mark and Laurie
Hi, it might be time for Centramatics and having your wheels re-balanced. Pop rivets are easy to do. And do not try to level your trailer with your stabilizers. [suggestions]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 08-26-2013, 04:27 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Hey Mark, some popped rivets here and there are part of ownership. tThey can be related to rough roads, too stiff tv/hitching equipment, or as Bob said, unbalanced wheels.
Ours pops them some times in the same area as yours. My guess is many that pop are in this same area.....near the door. Perhaps because the door opening itself causes a weak point in the structure. Check the things you can, get a pop rivet gun and rivets, replace them.
Hit the road, have a great trip!!!!!
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is online now   Reply With Quote
Old 08-26-2013, 04:37 AM   #4
"Cloudsplitter"
Thumbs up
X2
Your door problem could very well be caused by frame twist caused by too much weight on the stabilizers.
The Centramatics WORK.
Old 08-26-2013, 06:30 AM   #5
1981 31' Excella II
New Market , Alabama
What size load bars are you using? I would not think you would need much. Pop rivets are easy to replace. The door is a problem area because there is a BIG HOLE in the skin there. Also it is constantly being opened and shut and that causes rivets to wiggle loose. I would start by measuring the hitch weight and size the load bars accordingly. Also if you have a very stiff tow vehicle that could also cause problems.
Perry
Old 08-26-2013, 08:28 AM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Being the rivet problem is next to the door, and you have other door issues, that's where I would look.
As said earlier, be sure your stabilizers are lightly applied so as not to twist the trailer.
Many of not most Airstream doors come from the factory with less than optimal adjustment. You can do it yourself easily, but being very careful not to overdo it and bend something.
Here's an excellent video to adjust the door. We used it and our's closes easily and tightly without a slam and a crash.
doug
Old 08-26-2013, 08:59 AM   #7
aftermath's Avatar
Spokane , Washington
I purchased my 06 in 09 and it had been pulled around with a very stout TV. The hitch was pretty tight and there were three popped rivets on the inside, one by the door, one on the opposite side of the trailer and one in the bathroom. We also noticed that the drawer under the dinette would open during transit.
With my Tundra I dialed in the hitch where all is level and there is not nearly as much force on the bars as before. I also purchased 4 new tires and had them balanced. No centramatics for me yet. Everything is better now and even the drawer stays closed.
I did pop a rivet this summer when I had to jack up the trailer for a flat tire. I would check the hitch, balance the tires and that alone should help.
aftermath is offline   Reply With Quote
Old 08-26-2013, 02:32 PM   #8
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Hey guys thanks for the advice. I was intending to have the wheels balanced so I do that today. My wd sway bar was fairly tight the way the previous owner told me to do it. I've since loosened it, and I'm not sure when the rivets popped. I'll replace them and keep an eye on things. I guess a rivet gun from home depot is sufficient and I'm assuming aluminum shafted rivets. As for the door not shutting easily enough, I adjusted it up by cutting a slot in a metal washer, slid it through the hinge pin (top and bottom hinge) and it closes perfectly because the latch lines up with the striker bolt. The problem is, I'm sure the washer won't stay without some kind of keeper....any advice or help?
As for the wd hitch, it's rating at 12,000lb trailer weight w/a hitch weight of 1,000lbs or 1,200lbs depending on the position in the receiver on the truck. I'm towing with an 05 V8 Tundra with tow package.
Thanks again for the help and advice.
Mark
Old 08-26-2013, 02:47 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Markj...we have the same model/year of Bambi as you have, and we had a series of popped rivets in the same area ... it's not uncommon and can be caused by a number of factors and combination of factors, as noted in earlier posts. When we rebalanced the tires and got Centramatics the problem was reduced significantly. We still occasionally get a popped rivet here and there but the location is random, so I attribute it more to road stress than anything else. If the rivets pop in the same place repeatedly there is something else going on that needs attention. Replacing the rivets is not difficult .. and I might add that we have never popped a rivet that we have replaced.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-26-2013, 03:00 PM   #10
"Cloudsplitter"
Thumbs up
Mark
Mark,
You know the hitch rating, what weight bars are you using?
I think 800lb bars for your WD would be more than enough for your trailer.
Have you been to the scales to get the set-up diled in?
Old 08-26-2013, 03:02 PM   #11
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Mark
I'd say that WDH set-up that you are using is way over kill.... WAY overkill!
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-26-2013, 04:30 PM   #12
dkottum's Avatar
That's too heavy a w.d. hitch, and if it doesn't have tapered bars it's also too stiff.
Our dealer installed a 10K Equal-I-Zer on our new 20' Airstream a few years ago and it was too stiff for the trailer. I loosened the bars and lost some steering control, too light on truck front axle. We've got a new Airstream with the right w.d bars and everything is much better.
doug
Old 08-26-2013, 04:39 PM   #13
mapleton , Utah
To answer your rivet question, you want button head 1/8" rivets. All aluminum, body and mandrel. the shortest have a grip range of about .025 to .062 for 1 skin layer to a c channel and the next length is about .063 to .096 or so for attaching to the thicker ribs. The big box stores all carry a fair quality pop rivet gun and rivet assortment that should work fine.
tim
rumrunner is offline   Reply With Quote
Old 08-26-2013, 04:48 PM   #14
Salem , Oregon
Images: 18
Mark
Hi, Mark; I used "E" Clips on my hinge pins and they stay put.
Old 08-26-2013, 05:29 PM   #15
Wabbiteer's Avatar
Jupiter , Florida
For future readers.... Transmitted flexing showing up as missing rivets above the main entry door can flag a whole list of possible causes needing checking...
On old trailers a peek at outriggers and their through-bolt fasteners would be warranted when pop-rivets go missing and/or oxide black rings appear around them.
With the banana wrap system it too easy for previous owners to replace the cover sheet and leave chaos nicely covered up from accidents or blowouts.
My '73 trailer had sixish missing pop-rivets and same number with black rings, and we found busted/torn/un-welded outriggers plus C-channel bolts loose from rotten plywood and rusted/missing bolts. Just saying 'cuss it needs to be said
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Wabbiteer is online now   Reply With Quote
Old 08-27-2013, 01:06 AM   #16
Streamliner
Markj55's Avatar
2006 19' Safari SE
Santee , California
Hey thanks everyone for your input. I thought the sway bars were probably over kill but, that's what came with it so, what should I do?
By the way I believe the sway bars are rated at 800lbs. Did I mention I was going to Yellowstone? Maybe I'll stay home .....
By the way do any of you work .... I'm glad you're there!
Thanks, Mark
Old 08-27-2013, 04:13 AM   #17
"Cloudsplitter"
Thumbs up
Mark,
800lb tapered bars should work with your trailer. A trip to the CAT scales will tell the story.
