Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 07-27-2006, 07:15 AM   #1
Robfike's Avatar
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia , Alabama
Water heater bypass valve
Guys,
Last February I replaced the water heater in my 345. At that time I also converted it over to the one valve bypass for winterization.
I have noticed that the hot water flow rate is less than my cold flow.
Has anyone else experienced this reduced flow with the bypass type of hook-up on the water heater?
Now I am thinking about redoing it and going back to the three valve set-up.
Thanks, Rob
Robfike is offline   Reply With Quote
Old 07-27-2006, 08:25 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'm not sure how a one valve bypass would work but if the valves and piping are properly sized, there should be no noticable difference in the water flow. Usually the biggest problem that folks have is leaving a valve open by accident in the spring. Instead of getting the full flow through the tank, they get luke warm water caused by the bypass being open along with the tank valve. I think most of us have done it at least once.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 07-27-2006, 10:30 AM   #3
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
The bypass type deal is from Camping World. It has one valve you turn, and a one way check-valve. They sell a lot of them, so I am trying to see if anyone else is having the same problem.
If you do a "search" on my posts, (robfike) you can see the pictures of the install.
Old 07-27-2006, 10:35 AM   #4
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
Sorry, here is the link to the water heater install.
http://www.airforums.com/forum...ent-20704.html
Old 07-27-2006, 10:36 AM   #5
Robfike's Avatar
2012 31' Classic
Andalusia , Alabama
Well, I guess I don't know how to get the correct link.
Old 05-11-2014, 02:20 PM   #6
Waukesha , Wisconsin
Flow Problem
I have the same problem with a new trailer. Hot water only. City or holding tank. There is severe hot water line flow restriction. I'm thinking of taking it out.
swiencek is offline   Reply With Quote
Old 05-11-2014, 06:21 PM   #7
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
My 2012 Signature came with the same system. I did not experience any flow restrictions. I did, however, experience a sticky check valve that allowed antifreeze into the hot water heater. The system was changed to a 3 valve system last week in order to eliminate the problem. For some reason, a pressure valve, discharging overboard, was added into the hot water supply line. The valve leaks so now I have a constant drip when the system is pressurized. I must have been running out of opportunities to putter. Jim
Jim Flower is offline   Reply With Quote
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 02:10 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
