Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 10-17-2003, 10:55 AM   #1
Lido&Linda
Lido&Linda's Avatar
Profile:
Outside window trim
I just finished replacing the U shape fuzzy channel on the driver and passenger side.Now the trim on the outside, I can get the one that wraps around top to back side then to the bottom,but the piece that slides into the vertical frame between the stationary window and the slidder are not available.It looklike the same on the other windows except the rest of the windows is grey in color but this is black?
The U shape fuzzy channel is real easy to do and I DONT have to notch it going around the corner, just have to cut holes for the weep holes.Now the windows are easy to slide.
The Unleaded Zeppellin
Lido&Linda is offline   Reply With Quote
Old 10-17-2003, 11:19 AM   #2
Bfrank
Bfrank's Avatar
Profile:  Adams , Tennessee
Lip mold
I'm in the same boat with the lip mold I am currently
seeking a vendor to make this item and have emailed Airstream with a company that can and does make these type items for the
automotive industry. Maybe we could ask folks on this forum who need this peice of mold and get enough for everyone who needs it. I have yet to hear back from airstream as to wheather or not they will ever restock it so I am going to try to have some made
so I can complete my 310 referb at the present time I have both of my side windows removed and would like to get them back in
but I am waiting untill I can find the mold as it is much eaiser to replace while the window frame is out of the vehicle. If anyone reads this let's try to get a list of folks together with the footage that they would like to buy. I think the minium order to have something like this is 500 ft so between all of us I think we could probably use more than that. I have also heard thru the grapevine that even Airstream needs this stuff for their shop in Ohio but have none but not sure as that is only rumor. But if I wait on Airstream I may die of old age before I get any info from them.
Bfrank is offline   Reply With Quote
Old 10-17-2003, 12:00 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If you need someone to help use the molding count me in. I have some but it is only enough for a couple of windows
I bought it last year and never got to the job of replacing it on my 76. It wasn't that bad, I was just redoing the whole window and thought I would replace it. After doing 2 I kinda gave up
Now if I could find window tracks
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-01-2003, 08:41 PM   #4
farmerjim
Profile:
molding ect.
I just bought a 1984 310 limited and it will or does need the window seals ect. replaced so count me in if you can . I also have a friend that just bought a 1985 345 and I am sure his will need some also . Just keep me informed on the progress and where you can get the other available items.
farmerjim is offline   Reply With Quote
Old 12-03-2003, 11:15 AM   #5
Erika Schaette
Erika Schaette's Avatar
Profile:
to Lido and Linda
We bought a 1986 345 from "uncleneal" and are presently giving it a good work-over.
Of course also the fuzzy channels for the front side windows have to be replaced. Where did you find these channels ?
Also some advice how to replace these would be quite welcome.
As regarding to the lip molding ( I assume that these are the vertical moldings which are on the back of the front parts of all the windows ) you can also count us in to a possible purchase because they don't look very good any more either.
This is all for now but I know I will have a lot of questions later.
Karl H. Schaette
WBCCI 7111
Erika Schaette
Erika Schaette is offline   Reply With Quote
Old 12-03-2003, 11:23 AM   #6
farmerjim
Profile:
As I look at the above picture are those ice melters mounted on your bumper or are they to test the charging system? Man them are big lights!!!
Old 12-03-2003, 12:52 PM   #7
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Erika- nice garage and I thought I was doing ok with my vinyl canopy! Saw that coach at Top of Georgia sometime ago, glad it still has a good home.
Here is a copy from an earlier post on window channel stuff--
Go to your local glass company and see if they can match this number from their seals and weatherstripping catalog:
ASF126896
Its all rubber with a felt lip. When cut from the back every 1/4" at the corners, it conforms better than the fabric/wire mash stuff. It is also much easier to cut the weep holes for the drains.
It retails for about $15.-/8'
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 12-03-2003, 04:20 PM   #8
Erika Schaette
Profile:
Thanks Alumaniac,
We will try that out and keep tou posted with the results.
Erika ( and Karl ) Schaette
Erika Schaette
Old 12-03-2003, 06:31 PM   #9
aviontt
aviontt's Avatar
Profile:  , Connecticut
To bad your so far away. I need a place to work on my Argosy and it looks like you have some X-tra Space
aviontt is offline   Reply With Quote
Old 12-06-2003, 05:30 PM   #10
Lido&Linda
Lido&Linda's Avatar
Profile:
We got it from Inland R.V. for $2.65 per ft. The owner of Inland is Andy He is very knowlegable with air stream and have alot of parts.
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
Repost to part Forum (window part, 67 A/S) JimC Parts Archive 15 09-28-2003 10:45 AM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 08:11 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
