Originally Posted by GWallace
"Rosie Travelers"
I have attached a pdf file describing the function of the 12 Distribution Panel as it originally came from Argosy. Take a look at what I wrote and see it helps.
Gregg
Thank you so much Gregg for the information..!!
We ended up exchanging the alternator that we had put in back in April the night I wrote this post, we were holding a charge for a good 24 hrs or so and then started to see the volts go down.
We started our drive back home yesterday and ran the generator for about 15 min before we shut the engine and called it a night. This morning she started right up..
We drove out of our way to a service center that worked on AS.
Trailers, not MH’s, of course-but had a experienced mechanic check out the voltage at the isolator and fuse panel,
all which read as they should.
We also had an issue with the arm of the drivers wiper, the wind would swing the arm outside of the range-so we were dealing with that while the engine was running, afraid to shut it off.
We’re on our way to Raleigh, hopefully to find a campground open and plug in and go over your notes!
