Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > General Motorhome Topics
Old 02-14-2014, 04:35 PM   #1
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Furnace filter?
Is there a furnace filter on my 1982/3 310 turbo diesel??? Similar to a residential forced air furnace?
mayco is offline   Reply With Quote
Old 02-14-2014, 07:46 PM   #2
1974 Argosy 20
Kooskia , Idaho
No. And Suburban specifically states one is not to be added.
On my '83, 310 (no longer owned) I replaced the furnace and added a 4th duct to get the heat out of the unit. The original 3 ducts on mine were not enough and the unit kept cycling on and off with the high temp limit switch. Adding a 4 th duct and register was a big help in heating the rig, and keeping the furnace operating at a lower temp.
Old 02-14-2014, 09:42 PM   #3
mayco's Avatar
Thanks for the quick answer!
Old 02-15-2014, 07:49 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The reason is any screen or filter would reduce the air flow volume thus reducing the heat transferred out of the heater. This would reduce efficiency and run the risk of shutting the heater off on high limit.
2004 Excursion 4x4
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 08:15 PM
Furnace Problem Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-05-2011 06:30 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
2008 Safari 25FB - Water Filter Location JDEJV Water Heaters, Filters & Pumps 5 04-10-2011 06:08 PM
