06-28-2006, 06:33 PM
Chesapeake
, Virginia
CB Antennas
Anyone have a solution for the problem of needing a decent CB antenna for the classic MoHos? Mine has the split duty radio/CB service antenna with an adjustment at the splitter for the SWR on the CB. Needless to say, it doesn't make any difference . Reception and broadcasting are almost non-existent. I've checked the sub-forum on antennas, but nothing about CBs . If there's a thread about how to solve the antenna issue, I haven't found it yet. I'd really like to hear how someone solved the problem. Magnetic won't stay up there (I tried ), I don't really want to put any holes in the roof, but I'm wondering about using an adhesive to hold the base. Need a removable antenna since height can be a problem.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
06-30-2006, 12:04 AM
VE7REZ / W6
Desert Hot Springs
How about using a wide strip of Velcro....you can get Velcro with a sticky back similar to Duck tape in strength. Then the antenna base would also have that affixed to it so the antenna would still be removable.
I bet it would work fine.
Pete ...... VE7REZ /W6
06-30-2006, 09:34 AM
Frank S
peoria
Hi noiva--How about mounting a longer one (double the normal length) on your front or rear bumper. I have a 1993 Chevy Lumina APV Van that has a similiar problem with magnetic base antennas (body skin is composite material), so I mounted a double length antenna on the rear bumper, which goes as high as the roof. Reception is great. Don't forget to have a good ground connection.--Frank S
06-30-2006, 10:23 AM
1977 24' Argosy 24
Inverness
check out a cb shop at a truck stop they can set you up with a great antenna like a k40 which you can glue to the top and remove with a quarter turn. it is a 2 piece job . I did it to mine works fine..
bobchevy89
06-30-2006, 10:28 AM
Chesapeake
, Virginia
Reply to Frand and Pete
Thanks for the ideas, guys! I finally went to my local truck-stop CB place, and got outfitted with a bracket that I'm temporarily attaching to the awning arm (I know it's not "official" but it's just for a trial), a fiberglass whip antenna, and enough coax to get to my CB. Set the SWR yesterday, and it works great! If I can't figure a good way to mount this bracket permanently, I may try the Velcro idea, Pete. Hadn't even thought of the bumper mount idea, Frank, so I'll store that one for reference, too!
Really appreciate the ideas. That's what I love about this Forum .
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
06-30-2006, 10:32 AM
Chesapeake
, Virginia
bobchevy89
Bobchevy,
It just so happens I have a K40 I could do that with. I had thought of the glue idea earlier. Now I have three options. Thanks!
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
06-30-2006, 03:21 PM
The Hawk's Lair
1985 34.5' Airstream 345
BACK WOODS
Hi Noiva. Had the same delimma and solved it to my satisifaction in a previous thread. Works just fine and I used the original mount that airstream had installed on the mirrors that I replaced. Check this out.
http://www.airforums.com/forum...remove+mirrors
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
06-30-2006, 07:04 PM
Chesapeake
, Virginia
Cooperhawk,
Thanks for the thread reference. I did a site search before posting that first question, but couldn't come up with anything about CBs or Antenna except for radios. Anyway, great job! I may do something similar now that I've seen your pictures. I already have the Ramco mirrors, so adding an antenna mount just at the place they attach would solve the whole problem. I even have the bracket and whip .
Thanks again,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
