Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-27-2003, 03:22 PM   #1
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Oil Cooler Lines
Does anyone have a source, part number or replacement idea for the hard oil lines that feed the oil cooler built into the radiator (86' 345)? They run under the front frame support and around the passenger side of the shroud.
I've tried NAPA and AZ but they come up with "we have brake line". This is the last "to do" before I can fire her up again.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 08-27-2003, 03:35 PM   #2
PeterH-79MH's Avatar
Profile:
Images: 63
Some years ago, I replaced those lines on another MH. I went to a place that makes hydraulic pressure lines and had some custom made using my old fittings.
Once you figure out how to do it,
the instructions actually make sense.
_____________________________________
WBCCI Member at Large
PeterH-79MH is offline   Reply With Quote
Old 08-27-2003, 04:26 PM   #3
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Peter,
That is what the guys had to do on the engine swap. The lines practically fell apart when they tried to clean them . I am still looking for the paperwork so I can get JPAirstream a NAPA number for the lower hose.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-27-2003, 04:52 PM   #4
RivetAddict
swebster's Avatar
Wow, you guys are bumming me out. I should have been more careful when I removed them. So its off to the heavy equipment guys?
Steven Webster
AIR 1760
ThisOldRV.com
Old 08-27-2003, 05:00 PM   #5
Profile:  LOST , Hawaii
That sounds like tranny cooler lines, and replacements are usually made out of brake line. Nearly every AT vehicle has them, they are all formed differently and stocking them would be a nightmare. Oil cooler lines are usually hose and larger for the flow.
John
74Argosy24MH is offline   Reply With Quote
Old 08-27-2003, 05:02 PM   #6
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Look up hydraulics in the yellow pages.
Place near me called Royal Brass and hose makes that sort of stuff and it's reasonable. It's probably less expensive then going through GM. Last time I needed a specialized line they made it while I waited. I'm sure that would have been a order it an wait a week at the dealer.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-27-2003, 05:36 PM   #7
Profile:
Images: 63
Re: Oil Cooler Lines
Originally posted by swebster@myrvadvanta
.... that feed the oil cooler built into the radiator (86' 345)? ......
If I would going through the trouble having new lines made, I would strongly consider taking the oil cooling out of the radiator and installing a seperate external oil cooler.
It seems that all the rigs with the cooler built into the radiator are running 20 to 30 degrees hotter????
Am I totally of base with my assumption?
Old 08-27-2003, 06:20 PM   #8
RivetAddict
swebster's Avatar
I'm sure they are oil lines. John, you're right about the tranny lines. They're on the driver's side and look to be made from brake line. Someone installed an aftermarket trans cooler so those lines are routed into the radiator, then into the add-on cooler than back to the tran. The oil lines are in fact larger lines and come up from the rear of the engine, convert to flex below the crank pulley and then back to hard lines (bolted to the front frame support and terminate into the radiator on the pass side.
Well I guess I have a couple of options; One of my clients is a heavy equipment dealer so I could probably call a favor and get some lines made fast and cheap. But I like the idea of capping them off on the radiator and running an external oil cooler ($50 @ NAPA) as well. I would be very interested in this approach if people have seen lower coolant temps with this setup.
One thing I'm getting a little worried about is space in the nose. With two coolers and a soon to be installed condensor (mine was missing) can everything fit and not block airflow to the radiator?
Steven Webster
AIR 1760
ThisOldRV.com
Old 08-27-2003, 07:17 PM   #9
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
the idea of capping them off on the radiator and running an external oil cooler....
Caution is advised here. The cheaper air/oil coolers may be too restrictive, both in oil course capacity and air flow area. Deficient oil course capacity could cause too high a delta pressure and an excessive oil velocity which would not allow enough time for sufficient heat transfer.
My 345 also has both the tranny and engine oil coolers internal to the radiator, but I really don't know what could be done to increase cooling capacity.
An efficient external air/oil/tranny fluid heat exchanger mounted in front of the radiator would certainly increase the temp of the air to the primary cooling fins. The net benefit of the added external cooling equipment may well be a wash due to the added heat load of increasing the air temp hitting the front of the radiator.
I'm not saying it shouldn't be tried, just that some accurate temp measurements in and out on all three cooling systems (water, oil, and tranny) should be monitored before and after to assess if all problems are being addressed.
Last weekend I ran into a water temp running close to 220 F indicated while doing 63 in East Central Texas. Normal cruise previously was 210 F, but at ambient air temps at least 10 degrees cooler. This would lead me to believe that the radiator is nearly maxed out, but I want to try a cooler thermostat prior to replumbing any fluid flow.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 08-27-2003, 07:30 PM   #10
59toaster's Avatar
Atlanta , Georgia
Images: 22
My 88 Burb has a factory external oil cooler mounted infront of the radiator. I don't think the internal oil cooler is adding that much heat to the coolant. I have a temp sender in my oil pan and the oil temp AFTER it's been through the engine is only running 10-20 degrees higher then the coolant temp.
Now transmission is a whole different story. A transmission under load can put a LOT of heat into the radiator in a hurry. The Aux cooler you have is helping quite a bit. If it's as effiecent as the ones I have installed I doubt your tranny is running any hotter then the engine under normal cruise. The tranny temp gage in my other truck rarely gets above 160. I'll be installing the sender for the tranny temp this weekend so I will have a TH 400 reading soon.
1959 22' Caravanner
Atlanta, GA
Old 08-27-2003, 07:50 PM   #11
Just a member
Images: 21
Here is my 2 cents worth.
In both of my 70"s vintage coaches I have an imbedded trans cooler that is part of the radiator. Oil is a lone cooler that mounts in front of the radiator. On the 76 I added a transmission cooler and plan to do so on the 78.
I would be willing to bet that the reason all 3 are integrated in the 80s models is cost. Cheaper to build it all in one than have 2 or 3 individual coolers.
There is a forum member who redid the sheetmetal on the front of his MH and remote mounted oil and transmission coolers with air ducting and thermostatic fans to keep it all as cool as possible. I understand the concern for air flow, do you have room to one side or the other to mount the coolers?
Brett G
Old 08-27-2003, 08:19 PM   #12
Profile:
Images: 63
My 79 came with a factory installed external oil cooler as well. I added the aux trans cooler. No air flow problems.
If the 3 fluid radiator was such a great idea, why did they quit using them?
Old 08-27-2003, 08:37 PM   #13
RivetAddict
swebster's Avatar
Sheet metal is certainly a possibility. To be honest, I'm trying to keep this as simple as possible but certainly want to reduce operating temps and do it right the first time.
I don't think there would be much room for a side mounted trans & oil cooler as the vertical frame supports pretty much fill up the space between the grill/headlight housings and the radiator. There is plenty of room in the pass side fender well and I could see how ducting could work but this is getting beyond my current goals for this project. It certainly could be a good future project.
While most of you are very familiar with what this all looks like I've attached a pic that I took during disassembly which shows how the trans cooler is mounted to the grill. Its hard to see much else but adding an oil cooler to the other side would easily cover the entire grill and be directly within the airflow to the radiator.
One question on the trans...should I re-plumb the setup so the aux cooler is the only cooler or should I cool in the aux first then run it through the radiator?
Also, Dennis thanks for the caution on cheap oil coolers. You must be an engineer! If so I'm glad you're on our side!
Steven Webster
AIR 1760
ThisOldRV.com
Old 08-27-2003, 08:48 PM   #14
RivetAddict
swebster's Avatar
Pic of the Lines
By the way...here's a shot of the oil lines that got this started
Steven Webster
AIR 1760
ThisOldRV.com
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
HELP Emergency oil line busted! Astrodokk Airstream Motorhome Forums 8 10-30-2003 07:01 AM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 05:01 AM
GM/Dodge advice needed uwe On The Road... 16 08-17-2003 09:10 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
