Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-15-2002, 11:53 PM   #1
Crystaljean22
Crystaljean22's Avatar
Profile:
Question Motorized TV Antenna
We just bought an '83 that has a motorized TV antenna that won't raise. It seems to have power through the switch and we can hear a low hum at the motor site when the switch is activated. Also, when the switch is first turned on, the light is bright but then goes dim almost immediately, then goes completely out. The antenna doesn't even budge. We have checked the antenna to make sure it isn't stuck from lack of use or whatever. Any help or suggestions would be greatly appreciated. Thank you.
Crystaljean22 is offline   Reply With Quote
Old 04-16-2002, 05:43 AM   #2
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
I would first verify that you are getting 12 volts from the 12v distribution panel even when the light goes out. Things tend to go on the 'blink' when the fuses go bad. Peter can show you how to use your volt meter to test it. Just come to the next motorhome rally! If the fuse is going bad (like mine), you'll start to lose voltage after a short while (like your light going out).
p.s. The fuse is on my repair list!
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 04-16-2002, 10:03 AM   #3
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Just a thought to share with you- my 82 had the antenna itself replaced with a manual crank Winegard...but the older motorized switch set up left in place in the wall...non functional. Just wondered if yours might have been disconnected at some point also...checking the voltage will help, also checking the wiring at the crank motor itself.
I have been trying to come up with a replacement for the switch panel to make it into something functional. Cable tv outlet was one thought...
Old 04-16-2002, 04:10 PM   #4
PeterH-79MH
PeterH-79MH's Avatar
Profile:
Images: 63
Crystaljean22,
Have you tried raising the antenna in the very moment someone turns the switch on. The way it sounds is that you have power to switch and to the motor, but the voltage drops due to overload. The motor could be stuck or the gear jammed. Next step would be to remove the motor and connect it to 12 V without a load.
PeterH-79MH is offline   Reply With Quote
Old 06-11-2007, 06:38 PM   #5
Auretrvr
Auretrvr's Avatar
Profile:  Iowa City , Iowa
Power TV antenna needs replacement gear kit
Our 1983 310 has the problem that the antenna does not raise and lower, and it is because a plastic drive gear is broken. Not the same gear kit as the manual antenna lifts. Anyone know the manufacturer or a source for this?
Airstream OCD...there is no cure!
1983 Classic 310 Motorhome.
AIR 15765
Auretrvr is offline   Reply With Quote
Old 06-11-2007, 07:59 PM   #6
bkahler
Profile:  Jefferson , Arkansas
If I'm not mistaken we have all the manuals for the antenna on our 84 310 limited. I'll dig them out of the shop tomorrow and see if that is covered. Ours doesn't move up and down either and I haven't had time to look into it
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
Old 06-11-2007, 09:00 PM   #7
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
I tend to second Peter. Sounds like the motor cannot turn. You'll probably need to tear it down and see what's what.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-12-2007, 08:11 AM   #8
Auretrvr
Auretrvr's Avatar
Pictures of the power antenna and drive gears '83 310
Thanks for your help! I posted photos of my power antenna and the broken gear at
Web Forwarding
Click on the Photos tab and then click on a photo to enlarge it.
I will learn how to post photos on the forum next time!
Thanks.
AIR 15765
Old 07-16-2007, 10:30 AM   #9
Auretrvr
Auretrvr's Avatar
Parts are Available for the Braun Power Antenna
You can obtain the part I needed from:
Barker Manufacturing Co.
730 E. Michigan Ave.
PO Box 460
Battle Creek, MI 49016
Phone 269-965-2371
They were friendly, helpful and sent the part right out immediately (and now my antenna works FINE).
AIR 15765
TV antenna questions cindy Audio, Video & TV 16 05-13-2006 08:49 AM
Retractable TV antenna jack simons Audio, Video & TV 1 11-01-2003 09:55 AM
86' 345 TV Antenna Jim Tyrney Airstream Motorhome Forums 2 10-28-2003 09:23 PM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
