Old 06-05-2002, 01:57 PM   #1
2001 27' Safari
Springfield , Virginia
Rear TV Antenna Outlet
The 2001 Safari (27-B) has two TV antenna connections: one over the microwave cabinet with a signal booster button; the other in the bedroom without the booster. I get great reception using the front outlet with the booster; but when I take the TV to the bedroom and plug in there, I get no signal (whether or not the booster circuit in the front is turned on or off. Shouldn't the signal from the antenna be available at both locations? Or is the bedroom connection only good when cable TV is attached to the connection in the rear bumper?
Lew Brodsky
Springfield, VA
lbrodsky is offline   Reply With Quote
Old 06-09-2002, 11:36 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Re: Rear TV Antenna Outlet
Lew Brodsky
Springfield, VA
Lew,
That's a good question that I don't have an answer for at this time. We haven't used the bedroom connection at this point. I can only remember my old SOB trailer which had a separate outlet in the bedroom. If I remember correctly I thought the amp powered both connections.
Next time I get the Safari home (probably in the next 2 weeks or so) I'll check this out.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-18-2002, 10:44 AM   #3
jcanavera's Avatar
Fenton , Missouri
Images: 143
Lew,
I just heard from a 2003 Safari owner and her rear outlet gets an amplified signal when the front antenna amp is on. I'll check my 2001 out next week when its home.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-24-2002, 12:06 PM   #4
2001 27' Safari
Smile
Thanks, Jack. I'll have the dealer trouble shoot it next month when it's in the shop for warranty service.
Old 07-04-2002, 03:00 PM   #5
jcanavera's Avatar
Fenton , Missouri
Images: 143
Lew,
I checked out the rear TV outlet in my Safari and the booster in the front does drive the rear outlet.
Obviously you do have a problem.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 07-22-2002, 02:22 PM   #6
2001 27' Safari
TV Antenna
Lew reports:
The dealer (Parkview RV, Delaware) checked it out and concluded that the cable running from the front (lounge) outlet to the rear (bedroom outlet) is bad. Now the problem is, how to replace it! To route a new cable in the walls would require removing and replacing most of the interior wall and ceiling panels...a job nobody wants to do. The dealer will confer with the factory on a solution. My bet is they will run the new cable outside the trailer under the flooring and come back inside the trailer at the bedroom wall where the rear jack is mounted. This probably won't be done until after the summer. I'll let you know what was done at that time.
Lew Brodsky
Springfield, VA
Old 07-22-2002, 09:05 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Youch!
Not sure how they will do this since they still have to join the cable at the front and rear outlets. It would seem that traversing the wire up from the floor to each outlet would still be a bear since there are horizontal ribs to clear. I wonder whether they could pull the old cable out possibly tieing it to a pull wire.
Sounds like they don't check that cable for continuity. Keep us posted on this one Lew.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 12-11-2002, 10:46 AM   #8
2003 25' Safari
Kissimmee , Florida
Use the old cable to pull the new cable through! A carefull splice with no "bump" and it should work.
Dan
dmac is offline   Reply With Quote
Old 12-11-2002, 11:38 AM   #9
2001 27' Safari
TV Cable replacement
Progress report: the trailer is at Parkview RV Center in Delaware where they are working on replacing the TV cable now. Parkview's technician has been in touch with Airstream to solve this problem. Their solution appears to be to run a new cable outside, under the trailer, and come up through the wall at the rear cable outlet box. Pulling a new cable using the old cable will probably not work because the old cable is probably attached to the frame at points along its route. But thanks for the suggestion. I will post a "results" thread when the job is done.
Lew Brodsky
Springfield, VA
Old 12-11-2002, 12:03 PM   #10
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb You got it
Lew
Just wanted to share this info. Sounds like it's the same thing I was told this past summer. While I was at the factory having some work done, I inquired abt having the satellite dish installed.
Here's a list of reasons why it didn't happen~!
1. The frame wasn't strong enough to support the dish.(long term flexing action while mobile.)
2. Inquired abt the newer 'bat wing' TV ant., and was told that it could be installed, but the cable would have to come in thru the refrig vent opening. YUCK..
The reason for that was as stated in a previous post. The current TV cable is tied down to the ribs in the overhead. Not able to attach the new cable, and just pull it thru using the old cable.
I even asked abt a "skylight" in the hallway between the bedroom, and the closet area.(where it's darker during the day)
The word was that, the spacing between my overhead ribs wasn't wide enough for the skylight that A/S currently stock. They no longer stocked the older style that could.
It seemed that everything I asked for, there was a road-block~!!
I was able to get the Fantastic Fans installed. Let it go at that..lmao
Just thought you'd like to know.
ciao
BTW, ParkView is a very nice place~!! Nice folks there..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 12-14-2002, 04:26 PM   #11
2001 27' Safari
Smile Problem fixed!
Good news. Working with Airstream techs by phone, Parkview RV was told to remove the rear wall electrical outlet box and pull out as much of the TV antenna cable as possible. When they did this, they discovered that the Airstream factory had neglected to connect the splice the feeds signal to the bedroom antenna outlet! Another example of faultering quality control in Jackson Center! Parkview connected the splice and all works fine now. Problem solved.
Lew Brodsky
Springfield, VA
Old 12-15-2002, 02:37 AM   #12
1984 29' Sovereign
Savannah , Missouri
Thumbs up
LEW
Fantastic Job~!~ That tells you something abt "ParkView"......
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Motorized TV Antenna Crystaljean22 Mechanics Corner - Engines, Transmission & More... 8 07-16-2007 10:30 AM
TV antenna questions CindyH Audio, Video & TV 16 05-13-2006 08:49 AM
Retractable TV antenna jack simons Audio, Video & TV 1 11-01-2003 09:55 AM
TV antenna repairs lbf78SvgnInt31 Audio, Video & TV 7 07-28-2003 07:02 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
