04-09-2016, 10:24 AM
1977 24' Argosy 24
Hilden
, NRW
Junction Block
Hello everyone
I would like to know at the junction block is a fuse for the battery (batterie fuse 15 A), someone knows the function you have? that put the new fuse and breaks, and I donīt have an electrical circuit to know where the cable runs that fuse
Thank you
Herman
04-11-2016, 12:02 AM
1991 25' Airstream 250
Oxford
, Oxfordshire
Sorry Herman, you will need to re-phrase the question because it is a little unclear.
04-11-2016, 03:54 AM
1977 24' Argosy 24
Hilden
, NRW
Hello
under the dash is a fuse box , fur radio lamp etc and is one fuse 15 amp batterie, and I have a problem with this fus, and I dont know with function have
because the fuse spring out
some body know where go the cable our the function of this fuse?
Herman
04-11-2016, 05:16 AM
1982 31' Airstream 310
champaign
What items (electrical devices) will not work when this fuse is blown? Radio, lights, turn signals, brake lights, etc. etc. etc.???
04-11-2016, 06:28 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Can you identify which fuse from the junction box diagram?
04-11-2016, 11:11 AM
1977 24' Argosy 24
Hilden
, NRW
hello Martin
thanks for pic
is the third from right wing from above.
It is in the horizontal position , name is battery fuse 15 a
Herman
04-11-2016, 11:12 AM
1977 24' Argosy 24
Hilden
, NRW
the rest is working only this blown up, I dont know the function
04-11-2016, 12:05 PM
champaign
Are there any connectors (wires) plugged into the spots marked with a V?
04-11-2016, 12:14 PM
1977 24' Argosy 24
Hilden
, NRW
yes ,next too V
04-11-2016, 12:37 PM
champaign
gibt es irgendwelche in die Schlitze gesteckt Drähte markiert V auf dem Diagramm
04-11-2016, 12:42 PM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
Maybe a photo of your junction block would help explain Herman? Can you take one and share here?
04-11-2016, 11:17 PM
1977 24' Argosy 24
Hilden
, NRW
04-11-2016, 11:34 PM
1977 24' Argosy 24
Hilden
, NRW
here
04-12-2016, 05:26 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
The photo did not attach Herman
04-12-2016, 05:29 AM
Richmond
, Kentucky
Herman reposted it in post 13.
1975 24' Argosy Motor Home
04-12-2016, 05:48 AM
Keen amature
1975 20' Argosy 20
Chestfield
, Kent
That is just the diagram I sent with a circle added Brad.
A photo of his junction block will show the connection at the location marked V
04-12-2016, 06:10 AM
Richmond
, Kentucky
Sorry, I misunderstood who was asking for what!
Here's an under dash picture of Peanut's fuse block.
And a close up of the fuse block showing the red and wire wires plugged into the two sockets next to the battery fuse.
Looking at the wiring diagram for my 74 Argosy the red and white are not shown. From what I can determine the plugs are for coach builder add on's such as heater and A/C.
Here's my 74 diagram.
74 argosy.pdf
I think Herman will find that the white wire probably goes to either the heater/AC control. Not sure what the red wire would be to but it's bound to be some device added on by the coach builder.
Tonight after work I can try and trace the two wires down to see where they go.
04-12-2016, 06:07 PM
Richmond
, Kentucky
Ok, I checked out Peanuts wiring. The red wire goes to the cigarette lighter in the dash. The white wire appears to go to the heater controls in the dash. I couldn't verify the white wire for certain but that's my best guess based on the route it takes.
The white wire had a splice in the center of it that headed through the firewall and ended up going nowhere. It has a spade connector on it and is just hanging in space. Hard to say what it was originally for.
04-15-2016, 08:33 AM
1977 24' Argosy 24
Hilden
, NRW
thanks brad
I check tomorrow , is my day free for argosy
Herman
