Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 07-08-2004, 10:44 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Unhappy Speedo Woes - Parts Available?
About 500 miles after we purchased our '84 310 MH, the speedometer ceased to function. Took it to the shop and they replaced the plastic drive on the end of the cable, it worked for awhile, then failed again. They said the part of the old piece was still inside and preventing the new drive from fully engaging. So they fixed that. Now the speedometer works, but the odometer does not (I'm not sure if it worked for a while after the speedo repair or never worked after the initial failure).
The shop is now saying that both the speedo and odometer are driven by the same mechanism and that if the speedo works but odometer does not, the unit will need to be replaced.
Two questions:
1. Does this all sound correct?
2. Will I be able to find a replacement Speedometer?
guy99 is offline   Reply With Quote
Old 07-08-2004, 11:15 AM   #2
According to Airstream, the speedometers are no longer available.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-08-2004, 11:22 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Lutz , Florida
Images: 21
Send a message via AIM to thenewkid64 Send a message via Yahoo to thenewkid64
Aftermarket models are available. All you need is one that is designed for a GM application that is cable driven.
Here is a link to a site that offers many models.
http://www.egauges.com/default.asp
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-08-2004, 11:25 AM   #4
LOST , Hawaii
You can also try a speedo shop for repair or replacement.
John
74Argosy24MH is offline   Reply With Quote
Old 07-08-2004, 02:23 PM   #5
LOST , Hawaii
http://www.speedometershop.com/aut-pag.htm
Took a while to find this as I hadn't bookmarked it. I talked to them a few years ago, never used them as I changed gauges but they sounded pretty on the ball. If you can pull the speedo they can probably fix it.
John
Old 10-02-2004, 09:57 PM   #6
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
i found the speedo for the mh in California shop for $135 i replaced the defective one in my unit and about a year later that speedo was shot. do yourself a favor and put in a electronic speedo. i did and it works perfect, no mechanical cable to break or internal gears to jam. and it cost less than the teltech junk.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 10-27-2004, 04:05 PM   #7
87MH's Avatar
1978 31' Sovereign
Images: 292
Must Be a Virus
At mile marker 114 on Louisianna I-20 my Odometer ceased to function.
May it rest in peace.
The Speedometer continues to function. Since the next "big" project is a new dash panel - the timeline just moved up a notch.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
used parts gotair All Argosy Trailers 9 08-09-2004 07:31 PM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
