03-05-2007, 12:30 PM
#41
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
Hey, I think that window from Toaster came from me. Was the aluminum red in color? I have a lead on a few more, if anyone reading this is interested. Things are looking good, keep at it and post more pix.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
03-05-2007, 01:01 PM
#42
Addicted to Aluminum
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
FF
yep! you sent me pics of the poor airstream prior to being butchered. sooo sad...
you might recognize the other window here...
http://www.airforums.com/forum...6-post303.html
she's on the back of my 18 footer.
cheers, mate!
jp
• • • • • • • • 8576 • • • • • • • •
there's always room for one more!
03-05-2007, 01:04 PM
#43
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
forgot to ask, is there any reason why i can't run all of my sewer vents out a single pipe? that's teh way it was in my 18 footer. i can't figure out why a 19 foot globe trotter would need 3. i assumed i could run a vent tube up from the drain pipe to the grey tank, and put a "T" connection in there to run one from the black tank as well... leaving only a single hole/pipe sticking through the roof... much beter than having all 3, less than 3 feet apart, poking through the end cap! yuck!
jp
03-05-2007, 02:18 PM
#44
1965 17' Caravel
1968 28' Ambassador
Butte
, Montana
jp
Yes, I think there is a reason for the two vents. One for the black tank alone and one for the rest of the sewer system. Thats the way my Caravel is set up anyway. Not knowing how you are doing your tanks though, you might get away with one vent. You could plumb the sewer system vent and black tank vents together, I would think. Depends on routing of the pipes. In my trailer it was just easier to reuse the existing two holes and routing.
AIR # 7276, WBCCI # 7276
Project 2k5
Life is a journey, not a destination
03-05-2007, 04:43 PM
#45
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i'm planning on running the black and grey tubes half way up the wall before T-ing them together. that should give me plenty of vertical distance to make sure the vent stays clear. The way things are set up, the black tank can vent straight up from the top of the tank. So can the grey, in fact. i'm thinking at this point it will be ok to run them together. i can't tell you how much i hate those sewer vents poking through the rear endcaps. especially when you know how hard it is to replace those panels! ha!
jp
03-06-2007, 12:59 PM
#46
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
Another patch done!
for the arm-chair airstreamer, here's a little sequence i did at lunch today... vent-pipe-ectomy #2...
step one, remove that caulk mess around the pipe. there is NO way Airstream did this kind of work. i can't figure out why the forward vent has an aluminum cowl around it, and a clean simple seal, while the rear 2 looked like this mess. horrible!
anyway, i removed the big chunks with a screw driver and putty knife...
03-06-2007, 01:00 PM
#47
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
step 2, remove the pipe by pulling it into the trailer, then get rid of the crud-covered rusty ring...
03-06-2007, 01:01 PM
#48
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
the shell was covered with excess caulk and sealant... nasty stuff... so i let it soak for 2 hours in caulk remover...
03-06-2007, 01:02 PM
#49
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
next step was to clean all that mess up, and hit it with the buffing wheel to polish the metal. i like a clean aluminum surface to seal to... no dirt!
03-06-2007, 01:04 PM
#50
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i flattened out the bumps from the old screw holes, and taped the patch in place, making sure to mark one edge with a pen for re-installation. VERY important to make sure the holes line back up when you put it on...
... then i drilled, and clecoed away...
03-06-2007, 01:06 PM
#51
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
take it off, clean up teh aluminum shavings, and put a good amount of sealer on there. i used alcoa, so i wouldn't have to open up a fresh tube of vulkem. it works great. so far i have done 7 patches this way, and no leaks!
03-06-2007, 01:08 PM
#52
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
rivet time!
03-06-2007, 01:18 PM
#53
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i don't have a rivet shaver, $200 for one NON-motorized tool! so i dremel mine, clean the surface with acetone, and buff to a shine! ouala!
i know all this is basic stuff that we all already know and do... but it's fun to see the pic sequence, no?
jp
03-06-2007, 01:27 PM
#54
Colville
jp
YES Living vicariously until I retrieve mine from winter storage at the end of the month.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
03-06-2007, 02:55 PM
#55
1967 24' Tradewind
Alameda
curious
I don't want to hijack this thread...I have a question though, when you do an aluminum patch, what do you do to the patch so the edges of it are smooth? Or do you just cut out a piece of aluminum and put it on that way? Your repair job looks gorgeous. Nice work, I'm following this thread. I'm glad you rescued this baby.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
03-06-2007, 03:56 PM
#56
I say we save EVERY airstream and if we can't camp in em, we BOWL in them...
03-06-2007, 04:07 PM
#57
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
now the big question
how did you cut the aluminum into a perfect circle? Hmm?
56' Caravanner 'The Broomstick'
03-06-2007, 06:05 PM
#58
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
well, i spose i should bestow my technique to you fellas, huh?
1) measure the hole, and add an inch to the widest part (including any extraneous holes you'll need to cover up)
2) with a fresh piece of aluminum, scribe a circle with a compass of the desired circle. i then coat it with a fast drying dye/paint and scribe it again so i can see the line clearly as a bright white line.
3) with a metal shear, i make a series of straight cuts just up to the line, but not touching it. you could probably do this with hand shears, too if you don't have access to a big shear.
4) on a benchtop belt sander, rotate the piece flat, and sand away the extra material right up to the white line. then flip it over, and just touch it with the sander to get the burrs off.
5) with light sand paper, dress the edges so they're nice and smooth
6) draw a straight line across the circle, right through the small center dot left by the compass.
7) with a protractor, mark off an angle, based on how many rivets you want to install. on my smaller patches, i wanted 6, so i drew the first line at 60 degrees (60 X 6 =360). on the larger patch i'm putting in tomorrow, i used 30 degrees (12 rivets). stay tuned for pics of that!
8) once all the tick marks are drawn around the edges, come in an even 1/4" on each one, and punch a small dimple. Now clean the piece with MEK, and revel in your work.
the patch i made tonight took 20 minutes, and should take another hour tomorrow to install on the trailer. i'll post pics when it's done!
remember kids, you heard it here first! good luck!
jp
03-08-2007, 04:47 PM
#59
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
last patch...
... i promise! now i need to order my light. i'm doing the recessed Grote light here. i think it'll look great! better than a hole, anyway!
jp
03-08-2007, 05:13 PM
#60
1967 24' Tradewind
Alameda
thanks
Looks beautiful. Thanks for the step by step, I'm not there yet but I have a few holes I'd like to patch up eventually. Using a circle or oval pattern makes it look like it's not a patch, especially if you put something on there, like a bottle opener or some other useful gadget that attaches to the wall; a hook for towels, a metal sign of some kind, etc.
~ Hurley
ingrid
