06-04-2019, 08:28 AM
#1101
Sag Harbor
, New York
FWIW the search function in the blue box above works well mainly in the desktop version of this site, it appears. Not so well in the App apparently.
Peter
FWIW
06-05-2019, 06:14 AM
#1102
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Originally Posted by dlackey
Just want to say that thanks to the good information I’ve found here I successfully swapped out our 23FB water heater igniter board and mixing valve. Both procedures were pretty much plug and play. The Dinosaur board seems to have exorcised our hot water demons. All good!
Glad to hear that. Where did you source the igniter board. Our hot water heater is having trouble shutting off. It will boil over and pop the relief valve.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
06-05-2019, 06:35 AM
#1103
2019 25' Flying Cloud
2018 23' Flying Cloud
Ocala
, FL
Originally Posted by Craig0220
I have a 23FB and need to replace the bottom “slide in” seal for the shower door. I was hoping someone might be able to help me out with finding this... Or possibly the shower door manufacturer?
Also, is there a simple way to adjust the door for plumb? Any input would be greatly appreciated.
Thanks!
I replaced mine twice. I just called Airstream and they sent out a new part for free. Of course this was under warranty.
06-05-2019, 11:10 PM
#1104
2016 19' Flying Cloud
Miami Springs
Should the shower seat be soft? Mine fells like it is going to break...
06-06-2019, 11:22 AM
#1105
SR
2014 23' FB International
DFW
The shower seat material in my 23FB is hard (same material throughout the shower), but it does flex slightly when you sit on it. You can hear it when it flexes. It does not feel like it is about to break, however.
06-06-2019, 11:44 AM
#1106
2017 23' Flying Cloud
Cleveland
, Ohio
Water heater source
First I got all the serial numbers off of our water heater and the existing board. Then I called Dinosaur and they told me which board to buy and directed me to Amazon.
06-07-2019, 06:02 AM
#1107
Sag Harbor
, New York
Just came across our 2017 discussion about awnings. Did you get full awnings? Looks like you have been using the trailer and enjoying it over the last two years. Good stuff!
Peter
[click on orange arrow in quote to go back to Post #276]
Originally Posted by weirdstuff
Well, I agree with you. I have until manana to convince husband.
06-07-2019, 06:12 AM
#1108
Wildwood
, Missouri
Thanks. We have some long trips planned. I’ve got to get the hot water squared away.
2020 25GT FBT
06-07-2019, 05:26 PM
#1109
Walnut Creek
Inverter location?
Where is the inverter located on the 23FB? Pat
06-07-2019, 05:39 PM
#1110
2021 30' Globetrotter
East Northport
, New York
It is located under the head of the bed near the night table.
James
06-07-2019, 07:00 PM
#1111
Walnut Creek
Biker - thanks for the help. Glad it's not in some unreachable position. Appreciate the information. Pat
06-08-2019, 07:25 AM
#1112
2018 28' International
Liberty Hill
2017 23FB hot water red light
Should the red light be on if either the electric or gas switch is one. I would think yes but mine does not turn red. Any idea if it is a bulb or do I need to replace the assembly?
06-08-2019, 07:39 AM
#1113
East Northport
, New York
No... the light only comes on if the heater fails to ignite on propane.
James
06-08-2019, 08:09 AM
#1114
Bartlett
, Tennessee
I agree with Biker. That red light is a BAD thing. It does nothing at all when the electric element is on. If the propane burner is on, and working as designed, that red light does nothing. If the propane burner tries to ignite, and FAILS, that light comes on to alert you.
Bobbo and Lin
2017 F-150 XLT 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
06-09-2019, 06:48 AM
#1115
Liberty Hill
06-09-2019, 06:53 AM
#1116
Liberty Hill
Furance
Have a 2017 23FB and it is about 25f now. When I went to bed had the thermostat set to HP and it was working fine. The outside temp than was about 40. Got up the furnace was on and the temperature is about 25. Thinking this normal to protect the tanks and plumbing?
06-09-2019, 06:57 AM
#1117
2007 22' International CCD
Corona
The 23FB forum
The light may come on briefly as the propane tries to ignite. Once the propane starts burning, the light should go off. If it fails to light through three tries, the light stays on to let you know it failed.
They all seem to work that ways, but yeah, it’s relatively not that useful an indicator. Some have added other LEDs to their assorted switches to let them know switches are actually turned on, which makes more sense. Typically green indicates the circuit is turned on, and red should indicate a failure.
Even my tankless water heater works like the usual one. Steady red means it failed to light, a red flash when it tries to start is sorta normal. Not a clean indicator of status, IMHO.
06-09-2019, 07:03 AM
#1118
2015 23' Flying Cloud
Copper Hill
, Virginia
06-09-2019, 07:10 AM
#1119
Corona
Originally Posted by FloydCoVa
Yup. That’s the way it should be set up.
Ditto the water pump switch, fan power switches, etc. Any switch that does not turn a light on directly should have an indicator on it, but not so bright it keeps you awake at night, either.
We won’t get into how the use/store switch LED on that panel works, which is even weirder.
06-09-2019, 09:50 AM
#1120
Wildwood
, Missouri
Franktr, I wish I could answer your question. We carry a small portable heater. If we have an electrical hookup we use that. If we don’t, we run the furnace only.
2020 25GT FBT
