Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 12-13-2018, 05:23 PM   #2941
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
One of the real benefits of being an old geezer: living debt free!
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 12-13-2018, 07:03 PM   #2942
2008 23' International CCD
Pinson , Alabama
Yes, after the 1st time one broke. I purchased a piano hinge yesterday and will give that a go. Heading to VA next week and when I get back will be pulling up floor vinyl to figure out why we've a hole just 1-1/2' from the door. This repair will be interesting.
Thanks Y'all
RosiesGuy1 is offline   Reply With Quote
Old 12-13-2018, 07:14 PM   #2943
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
Dadeville , Alabama
Thanks Y'all
Hey just FYI you are only 2hrs north of me. If you ever need any help I’m close.
Old 12-13-2018, 09:00 PM   #2944
Pinson , Alabama
Thanks ! I'm sure I'll be asking a lot of questions. If ur ever up this way let me know!!
Old 12-14-2018, 12:41 PM   #2945
CAB & DAB
dbdreams's Avatar
2019 19' Flying Cloud
Brenham , Texas
Any other 2019 23CBs yet? Would like to compare a few shots from the refrigerator compartment
I feel the wiring of the fan in ours is not as built.
David
dbdreams is offline   Reply With Quote
Old 12-14-2018, 05:16 PM   #2946
Pinson , Alabama
Piano hinge
Thanks Y'all
Installed the hinge this morning. Went ok, only one damn came outta my mouth! I'm hoping to also post a pic of completed hinge and one of another problem. Trying to figure out why just at this location (exactly where measure tape is shown) I have soft floor as in rot. Just a weird place!
Old 12-14-2018, 05:17 PM   #2947
Pinson , Alabama
pic
floor soft spot
Can't seem to upload pic - it shows file selected but doesn't post it - sorry
Old 12-14-2018, 05:18 PM   #2948
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
floor soft spot
Pic did not post
Old 12-14-2018, 05:35 PM   #2949
RFP
RFP's Avatar
Hurst , Texas
David
Yikes! Why not go ahead and post a photo of yours?
And some stuff
Old 12-14-2018, 06:08 PM   #2950
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I’m going to install a Victron BMV 702, Shunt and Bluetooth dongle tomorrow. I have a plan just gotta implement.
I’m going to use the existing cat5 prewire Cable Airstream installed by dropping a pair of wires and using the 6 needed.
This will allow me to mount the display over by the inverter switch and tank monitor.
I know, I know. I don’t have to use or see the display because I have Bluetooth, but I want to be able to see it.
As usual I’ll document the process and let you know how it goes.
Old 12-14-2018, 06:23 PM   #2951
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Go Ronnie!!
Troutboy
Troutboy is offline   Reply With Quote
Old 12-14-2018, 06:24 PM   #2952
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Originally Posted by Troutboy View Post
Go Ronnie!!
Rich,
Without you it would not happen.
Old 12-14-2018, 06:32 PM   #2953
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here’s a little prep work.
ID:	329673   Click image for larger version
Old 12-14-2018, 09:59 PM   #2954
2007 22' International CCD
The 23D thread
GMFL, et al, I’m sure Lester will agree with me on this:
I wouldn’t bother with soldering. A proper crimp covered with adhesive lined marine heat sink will be more durable. Reason is the solder stiffens the cable strands and makes them prone to breakage from vibration. No connection to a stranded wire in Aeronautical or space systems is EVER soldered. Just a high quality crimp with calibrated and inspected crimping tools.
For us retired Boeing folks, a quality ratchet crimper or a decent hydraulic one is what i use. I’ll pass on the calibration hassle and just do a pull test. If it does not come loose when I firmly yank on it, it’s just fine...
Old 12-15-2018, 05:56 AM   #2955
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Thumbs up
rmkrum,
Thanks for the heads up.
Old 12-15-2018, 06:24 AM   #2956
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
Ronnie , I certainl agree. Plus insulation should touch the lug, to be correct.
Clint
Fair_Enough is offline   Reply With Quote
Old 12-15-2018, 07:57 AM   #2957
CAB & DAB
dbdreams's Avatar
Brenham , Texas
Got back home last night so can post a couple of shots of the refrigerator area and what I don't like. Will work on fixes as time around Christmas allows. Wires are just draped over the tubes by the connecters and top tube touching the top of the cabinet. Did not catch everything at the dealer's, imagine that!!
Will be happy to talk about the dealer one on one if anybody wants to, don't want to start a dealer bashing on this thread.
Happy Saturday all
David
ID:	329687   Click image for larger version
Old 12-15-2018, 08:19 AM   #2958
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Happy Saturday all
David
David
That looks about par to the course. Airstream wiring 101 “just hide it”.
They have got to get better at keeping things neat and tidy.
“Out of sight, out of mind”.
Old 12-15-2018, 02:50 PM   #2959
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Sneak peek
Shunt installed
Rivnuts added to back wall
Wiring cleaned up
Used Airstream solar controller prewire for Victron BMV monitor.
I’ll do a full write up and blog entry soon.
And yes I did swap the crimp out I soldiered with one that was just crimped
ID:	329714   Click image for larger version
ID:	329716   Click image for larger version
Old 12-16-2018, 08:21 AM   #2960
2013 23' International
Delaware , Ohio
Originally Posted by GMFL View Post
Sneak peek
Shunt installed
Wiring cleaned up
Ronnie,
Nice work! We will be getting into this area in a few months and look forward to your blog update.
Jim k
2013, 23D International Signature
2015, Toyota Land Cruiser
Jim k is offline   Reply With Quote
23d
Secret doors on 23D CCD bolerama 2006 - 2010 International 24 04-05-2010 12:44 AM
2010 23d Int. Does this price sound right? Jezibels Buyer Guidelines 8 10-12-2009 06:49 PM
NEW 2007 International 23D Signature Series CCD 23' Colonial Airstream Commercial Listings 20 02-04-2007 09:48 PM
