Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums
Old 02-20-2009, 11:48 AM   #1
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
New Bambi 422 for Europe
NEW AIRSTREAM BAMBI | European Motor News
Too bad they can't seem to incorporate some of the features of the Euro models to the domestics since they appear to all be built here....
Here is a link to the Airstream UK site:
http://www.airstreameurope.co.uk/
Old 02-20-2009, 01:38 PM   #2
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Thanks for that. And it's being debuted in my wife's hometown!
I like some of those floorplans. I'm still bugged though that older Caravels were able to fit two separate sleeping areas - a front and side gaucho - into the same size trailer as that new Bambi.
But I'm really digging a 684 - free-standing "queen" bed at 3880 lbs dry....
mutcth is offline   Reply With Quote
Old 02-20-2009, 03:50 PM   #3
HDS
Did I read that right, they have hot water heat?
HDS is offline   Reply With Quote
Old 02-20-2009, 03:56 PM   #4
soldiermedic's Avatar
Florissant , USA
So it's the Safari Sport 17" floor plan with bath in a Euro model?
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 02-20-2009, 04:01 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That's one cute little guy, thanks
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 02-20-2009, 05:17 PM   #6
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Yes you did...
Alde*3010 Compact HE Combi Boilers - Alde UK
I quote..
"The Alde 3010 Compact high efficiency combi boiler is ideal for central heating systems in boats, motorhomes, caravans and portable cabins. It provides 7.5 kW of heat, through up to 14 m of convector. The boiler gives you central heating that is clean, efficient, silent, reliable, and versatile, powered by LPG and/or 230 V electricity. With its multi-stage burner, the boiler only uses as much energy as needed to heat the living space, eliminating waste.
All system connections are on one side, allowing the unit to be installed in the smallest of spaces, and the flexible flue means you can position the boiler and terminal where you want. The control panel cable has moulded quick connectors making the job of installing the boiler easier and safer. Why not invest in the additional engine heat exchanger, so you can transfer engine heat into your central heating system while on the move, making use of all that free energy!
The Alde 3010 Compact HE combi boiler comes with optional 230 V pump, for super-fast heating from cold with no battery drain, and the optional installation kit containing: control panel, control panel cable (8.5 m), side or roof flue terminal, outlet exhaust hose, inlet air hose, expansion tank, expansion tank cover, non-return valve, safety drain valve, circulation pump.
Full Technical Specification
Note: Alde UK recommends the use of propane in this system within the UK.
  • Dimensions: Height 310 × Length 490 × Breadth 340 mm
  • Weight: 14 kg
  • Max gas power output: 5.5 kW (propane), 6.4 kW (butane)
  • Max electric power output: 2.1 kW
  • Max gas consumption: 405 g/h (propane), 460 g/h (butane)
  • Gas pressure: 28-30/37 mbar (I3+)
  • Fluid capacity: 8.4 L (fresh water), 3.5 L (glycol)
  • Max fluid pressure: 3000 mbar (fresh water), 500 mbar (glycol)
  • Max current: 1 A (start-up), 0.4 A (LPG), 0.2 A (230 V), 0 A (optional 230 V pump)
  • Min flue length: 0.5 m (side), 2 m (roof)
  • Max flue length: 1.5 m (side), 3.5 m (roof)"
  • Interesting ...
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Widebodies in Europe? golddigger Travel Beyond US/Canada 22 07-24-2011 05:01 AM
on the roads of Europe frederic.c01 Travel Beyond US/Canada 13 10-22-2010 11:19 AM
Europe you can help me ....towing in europe puppybear Global 'streaming 2 12-04-2008 09:32 AM
WHO IS STILL OUT THERE?europe calling Perry Other Rallies & Events 6 08-18-2006 02:37 AM
Airstreams in UK and Europe guy99 Networking 1 02-27-2005 03:11 PM
