Welcome to the AirForums!
Yes, the knob holding the metal flap should unscrew. Doesn't have to unscrew all the way, just far enough to let you swivel the metal flap.
Handy hint, you can get a better grip on the knob for turning it if you wrap the knob with a postal-sized rubber band. If you still can't muster enough strength, then leaving the rubber band in place and gripping the rubber band with a pair of pliers will give you enough leverage, without damaging the knob very much.
