Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1966-68 Caravel
Old 03-15-2011, 07:52 AM   #1
cojer's Avatar
1966 17' Caravel
salida , Colorado
To sway or not to sway?
just curious: do any of you caravel owners use sway bars while towing...it kind of seems like big overkill to me but i'm interested in what your ideas on the subject are
thanks jer
cojer is offline   Reply With Quote
Old 03-15-2011, 08:00 AM   #2
thanks jer
Any sway, can become instantly dangerous, that can lead to a total loss of control.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-15-2011, 08:02 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The topic has come up before. There are a number of people who use weight distributing hitches on smaller trailers. A few use sway control of one kind or another as well.
http://www.airforums.com/forums/f464...rol-17986.html
Old 03-15-2011, 08:05 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Drawtite makes a single-bar wd package specifically for smaller trailers, up to 4000 lbs gvw:
Single Bar Weight Distribution Kit for A-Frame Draw-Tite Weight Distribution 3205
Old 03-15-2011, 08:10 AM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I am in favor of some type of sway control when pulling any trailer that is heavy enough to require trailer brakes. A trailer can pull great through passing semis and severe cross winds. The true test is when you need to take any type of evasive action at highway speeds. This can start a sway action that can be catastrophic.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 03-15-2011, 09:20 AM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We towed a large model Coleman popup years ago. We loaded it up too including bicyles and canoe on top. When considering buying our AS I remembered the few times when the tent trailer 'wiggled' sometimes. Sway bar for a tent trailer? Rediculous I thought! Our AS has a sway bar as well as WDH and tows very smoothly........and much more safely.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-15-2011, 10:15 AM   #7
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I am defineatly in Favor of some kind of sway control even on you little trailer. What you dont understand is that little trailer is far worse in the sway department than a long trailer. Because it is short.THe whip will be almost instantaneous and severe.Because its sway back and forth is so much faster you cant catch it.It will put you out of control before you even realize what has happened.
SO its entirely up to you .CRASH OR NOT TO CRASH its your decision. Id put on one bar and CHOSE the latter
GOOD LUCK
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-15-2011, 10:40 AM   #8
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
thanks jer
You don't say what type of tow vehicle you have. Often folks with a small trailer tow it with an SUV or some other type of short wheel base tow vehicle. The short wheel base of the TV combined with a short trailer will lead to more sway than a larger rig encounters.
Steve & Beth
TAC AL-4
AIR 22763
07' Classic 31, 11' Dodge 3500 Cummins
au_ee is offline   Reply With Quote
Old 03-15-2011, 10:59 AM   #9
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
YES!!!. My first trailer was an early 70's 17ft. single axle Oasis (not AS) that I got real cheap because the PO managed to wrinkle all four corners and the back of his honking big station wagon when it got away from him on the road. It had WD but no anti sway bar. This was all back in the 70's, but lesson learned............Phil.
pgr32e is offline   Reply With Quote
Old 03-15-2011, 11:44 AM   #10
cojer's Avatar
1966 17' Caravel
salida , Colorado
well it's starting to look like everybody is pretty much on the same page on this one. it's just that i've towed alot of different trailers over the years and never used a sway or wd and i've never crashed one or really ever had any trouble...just lucky i guess? when i bought my as it came with a sway and wd that the p.o. bought but never really used...guess i'll try and hook it up.
Old 03-15-2011, 02:48 PM   #11
Wise Elder
Jammer's Avatar
2010 30' Classic
Sway is much worse with travel trailers than with nearly anything else.
I believe that the main reason is that travel trailers have more of their weight towards the ends, compared to boats and utility trailers, where the weight is concentrated closer to the axles. The amount of wall area exposed to crosswinds also plays a role.
Old 03-15-2011, 03:23 PM   #12
au_ee's Avatar
2007 31' Classic
Pulaski , Tennessee
On boats, due to the majority of the mass being at the rear of the boat they place the trailer axles towards the rear which is where the overall center of mass is located. On a TT the mass is more evenly distributed and the center of mass is near the center of the trailer which is where the wheels are placed. Therefore the geometry of the two are different with a greater distance between the hitch and the axles on the boat trailer than on the TT.
Steve & Beth
TAC AL-4
AIR 22763
Super loud cranking groaning clicking hitch! J5MM Hitches, Couplers & Balls 31 04-01-2011 09:50 PM
swaybar gwag23018 Hitches, Couplers & Balls 6 01-30-2011 03:14 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
1987 Airstream Sovereign 31 foot - hitch and sway bars? professorbol Hitches, Couplers & Balls 7 03-28-2010 06:54 AM
The Demon behind the car carriers and sway control arcamedies Hitches, Couplers & Balls 14 03-21-2010 02:00 PM
