All vent and window hardware has been taken apart and restored.
Chasis was completely restored rust was removed and repainted and an undercoat of rust preventative was applied.
Total body panel repair side lower curbside panels replaced, one in the front and one on the back corner. Removed the clear coat on the entire trailer and polished.
New clearance and taillights, new break away and 7 wire plugs
New window and door seals and for the skylights 3
New window screens and plexiglass for the vents 3
Removal of all old interior
New decking sub floor at front and back of trailer
New insulation under subfloor and the interior before placing the walls back Polyshield rigid insulation installed beneath the entire floor.
New valves and switchblades installed on waste tanks yes
New core tech laminate flooring Smartcore vinyl flooring installed throughout the entire trailer.
New shower in the bathroom with new fiberglass sheeting and shower base.
New toilet
New PEX water plumbing
New Attwood water heater
New furnace duct work
New furnace
New LP lines and regulator with valves for every appliance.
Interior walls removed, cleaned and new insulation placed in the walls. Custom panel walls were added between the kitchen/bedroom and bedroom/bathroom
New interior wall paint.
New Solid oak custom to fit cabinetry and hardware new cabinets were installed built from white faced birch wood using soft close concealed hinges. All doors for cabinets are frameless while closet doors are inset 2 .
New built in microwave
New TV's 2 24 TV s and the one in the bedroom is a Smart TV.
New sinks bath and kitchen with new faucets and with custom cabinets.
New 110 v outlets and switches along with 2 USB box outlets.
New breaker box and breakers 240 volt/50 amp with built in converter.
New 12 v wiring and switches.
New LED lighting all interior lights.
New couch cushions and upholstery.
Custom solid surface counter tops Custom built spruce counter tops with a stain and durable epoxy finish in the bathroom, living room and kitchen.
New Custom made curtains and hangers.
600 hours labor start to finish.
New Awning Zip Dee/manual
Polished exterior.
New Furrion gas cook top.
New stereo system 850 watt kicker amplifier with two 6 x 4 kicker speakers with JVC stereo head unit.
All new tires.
New custom built wrap around couch with underneath storage. Table can be lowered in the living area to make into another bed using back couch cushions and the table is made with the same epoxy finish to match the interior but has not been installed yet .
Exterior has been restored with all new molding and lights.
Exterior emblems have been restored and painted.
New Coleman AC unit.
View this ad at Airstream Classifieds -
1974 Airstream Sovereign
