Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Click Here to Login
Old 11-09-2014, 11:58 AM   #1
1995 36' Classic 36
Ludington , Michigan
Brake Job Spartan EC2000
I inspected the brakes carefully on the pre-purchase. They looked like new and the owner said it got new rotors, pads, and a air/hydraulic unit just before he bought it. After 4 years I decided to check the brakes and flush the system. All four calipers had cracked boots. This can lead to the pistons getting seized from corrosion. I couldn't get new boots without buying caliper rebuild kits. They ran about $50 a wheel so it wasn't too bad.
Name:	ImageUploadedByAirstream Forums1415557878.792855.jpg
The brakes were really easy to work on compared to a lot of light vehicles I've worked on. The retaining clip is held on by one bolt and drives out easily. The pads were still in good shape but new ones were pretty cheap so I replaced them while I had the calipers off. I did find that someone used brass fittings to connect the brake lines to the calipers. Not a good idea as they are pretty easy to bust off. There was also no way to remove the lines without rotating the whole caliper as there was no swivel fitting. Also leads to issues of not being able to properly torque the fitting. I believe this was the factory installation.
Name:	ImageUploadedByAirstream Forums1415558425.760333.jpg
Name:	ImageUploadedByAirstream Forums1415558482.500548.jpg
I had new brake lines made up at a local shop with the proper steel ends.
The Pistons popped right out with the air hose. Be sure to put a wooden block in to keep one from popping all the way out with no way to get the second one out as the chambers are interconnected. I don't learns fast but what I learns I remembers. Wear splash goggles as the propylene based brake fluid can cause permanent damage to your eyes.
Name:	ImageUploadedByAirstream Forums1415558897.807346.jpg
Name:	ImageUploadedByAirstream Forums1415558927.515764.jpg
The bores on the calipers looked like new which was a relief as the Meritor calipers run about $800 a piece and about 1/2 that for remans. Assembly takes a bit of a technique that you will master by the 4th caliper.
Name:	ImageUploadedByAirstream Forums1415559291.470696.jpg
Total cost was about $500 including hoses and a gallon of Castrol Dot 3/4 to flush and fill the system. The job really wasn't PITA I expected.
Next write up will be on installation of a Pacbrake.
Dave...
Kota is offline   Reply With Quote
Old 11-10-2014, 10:52 AM   #2
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Nice work!
mayco is offline   Reply With Quote
Old 11-11-2014, 12:33 AM   #3
Vycan's Avatar
1994 36' Classic 36 Diesel
Colorado Springs , Colorado
Great writeup! Who'd you get the motorhome from?
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 11-11-2014, 07:05 AM   #4
1995 36' Classic 36
A couple in Seattle about 4 years ago.
Brake Job on P30? 92landyacht Mechanics Corner - Engines, Transmission & More... 8 04-24-2014 04:43 PM
Spartan Mansion 33 :: 1950 Airstream Spartan Mansion j2m Airstream Registry Discussions 0 01-28-2012 09:38 AM
Found something weird doing my first brake job. uniquemicro Brakes & Brake Controllers 4 09-20-2009 12:14 AM
Brake job - now they're broken floridartist Brakes & Brake Controllers 25 08-13-2009 12:00 AM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
