10-16-2022, 10:49 AM
#501
1954 22' Safari
Ringmer
, East Sussex
Originally Posted by 66Overlander
You have an Ohio built Airstream as confirmed by the leading "0". Some years the serial number plaques listed both plant locations. Some early 1953 Ohio Airstreams had plaques that only listed California before they got their own plaques made.
Specifically, O6027 decides as a 1954 22' Safari built in Ohio. It is not a 22' Flying Cloud. Totally different interior layout/floor plan. Ohio built 22-footers as both Safari's and Flying Clouds in 1954. California built only Flying Clouds.
Thanks so much Joe. I really appreciate that. Very helpful!
Cheers
Niall
10-17-2022, 05:37 PM
#502
Kansas City
, Missouri
California wheel wells were flat topped thru 1955. They were then slanted from 1956 thru 1958, so 1954 thru early 1957 California whale tail Airstream wheel wells came both ways. By my best estimate your serial number 7966 suggests you have a late 1955 California Flying Cloud.
OK, thanks, looks like i have a 55 then. I did read on here that whale tails were exterior panels only, or maybe i read it wrong, because i have WT panels in and out. Any comment on that one? thanks in advance ,Randy
10-17-2022, 07:33 PM
#503
1966 22' Safari
Fredericksburg
Randy, we have the interior whale tail as well on our 55.
10-18-2022, 06:26 AM
#504
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Bubba is correct at least some 1954 to early 1957 whale tail California trailers came with whale tail rear interior endcaps, but I have not studied that detail, so I cannot say if they all did or only some did.
Joe
WBCCI/VAC #702 & #6768
10-22-2022, 03:04 PM
#505
1966 22' Safari
Fredericksburg
195 Flying Clouds Found
Adding 64 Porsche's FC to the registry for a total of 195:
CaptainJones Flying Cloud Registry 10-16-22.pdf
12-15-2022, 08:57 AM
#506
1962 22' Flying Cloud
Vista
1962 FC Land Yacht
12-15-2022, 09:01 AM
#507
Vista
12-15-2022, 06:21 PM
#508
1966 22' Safari
Fredericksburg
196 Flying Clouds in the Registry
Your '62 FC is a new addition to the registry: CaptainJones Flying Cloud Registry 12-15-22.pdf
Congratulations and good luck with the reno!
07-18-2023, 12:19 PM
#509
stangafner
1966 26' Overlander
Encinitas
1955 Flying Cloud to add to registry
We bought a '55 Flying Cloud about 12 years ago to park and use as an extra room for one of our kids that needed a place to live for a couple of years. We're now starting to renovate the beast and attempt to get it back on the highway. Lots of work ahead, but excited to be doing it finally!
1955 Airstream Flying Cloud
Ser. # 7862
Located in Encinitas, CA now.
07-18-2023, 01:08 PM
#510
1966 22' Safari
Fredericksburg
Ser. # 7862
We will list your 55 FC on the Registry today. If you are planning to renovate the 55, please consider starting a renovation thread so we can follow along with your progress. If you have any questions on the parts and pieces, if I don’t know the answer, someone else will. Good luck
07-18-2023, 01:47 PM
#511
1966 22' Safari
Fredericksburg
stangafner's 1955 FC makes 197 Found
07-19-2023, 01:35 PM
#512
redondo
, CA
I just bought a 54 flying cloud. number O3199.
07-19-2023, 02:57 PM
#513
1966 22' Safari
Fredericksburg
twood's 1954 makes 198 FCs Found
twood,
Congratulations on your purchase. If you plan a renovation, start a thread so we can follow along! Your trailer is a new entry to the Registry:
CaptainJones Flying Cloud Registry 7-19-23.pdf
Good luck,
07-19-2023, 03:36 PM
#514
redondo
, CA
Originally Posted by Bubba L
twood,
Attachment 434463
Good luck,
The bones were done. New axle, electric brakes, tongue, new 7 gallon propone tanks, gray and black tanks, plumbing, electrical, tankless water heater, AC, 2 fantastic fans. Interior has new floor and uphostery, rear bed and toliet. Wood work in excellent shape. I just removed stove and ref (too old) and replaced with retro style. One issue, trailer sways way too much. looking for solution. Also, I dont know how tostart a tread
07-19-2023, 04:32 PM
#515
1966 22' Safari
Fredericksburg
New Thread
Scroll down to the very bottom blue bar on the page and click on "Site Map". Scroll down the list of threads to the Flying Cloud section (under the Airstream Knowledgebase) and click on "1950-1955 Flying Cloud" (under Flying Cloud). A new list will display and again click on "1950-1955 Flying Cloud" that follows "View Full Version:". This takes you to a list of all the threads in the 1950-1955 Flying Cloud forums; click on the "New Thread" button on the left and above the title on the page.
07-25-2023, 12:29 AM
#516
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
You have one of the first few 1954 22' Flying Clouds built in Ohio. It was built on March 12, 1954. Ohio had only added the sloped rear to increase the Flying Cloud from 21' to 22' in January 1954.
Joe
08-01-2023, 12:32 PM
#517
redondo
, CA
Found out that this flying cloud was the first prototype for the whale tale. It was scheduled for the airstream museum. Top rear is like others but then it drops straight down. Apparently, they were trying to figure outt the profile.
08-01-2023, 03:25 PM
#518
1966 22' Safari
Fredericksburg
twood, that’s interesting. I thought the only whale tail that Ohio had a hand in was Wally’s 1955 Bubble. So yours is a whale tail with an Ohio plant number 03199? Thanks
08-11-2023, 10:01 AM
#519
1962 22' Safari
2016 30' Classic
Southeast
, Michigan
Ohio never built any whale tail, not for Wally, not on a Bubble. All whale tails were built in California. BTW, Wally's 1955 Bubble, with the magnesium frame, was built in California - it has a California serial number.
I did examine a California Flying Cloud with a whale tail at the Airstream Club International Rally this summer that is the lowest serial number I have ever seen with a whale tail. I wonder if that is the unit mentioned in this thread. The angle of slope for the rear window was more than the angle of slope for the aluminum panel below the rear window suggesting they were trying to figure out how to fit it all together. That suggests that the trailer I saw could be a "prototype", or at least a very early 1954 whale tail. I have only seen one other Airstream before with similar mismatched rear angles, but I did not keep notes as to length or serial number.
Joe
08-11-2023, 12:01 PM
#520
1966 22' Safari
Fredericksburg
Joe, thanks for the clarification and information. Seems like there will always some oddities discovered.
