Title:
I just posted a new ad on Airstream Classifieds.
WHEELS: Original equipment 16” aluminum wheels from a 2016 Airstream Classic, new high-pressure (80 psi) valve stems in July 2018, good cosmetic condition but not perfect, no center caps > TIRES: Michelin LT225/75R16 LTX M/S² (load range E – 80 psi max.) mounted and balanced on the above wheels, date codes “1215” and “1315” (manufactured weeks 12 & 13 in 2015), never damaged, no flats, no sidewall cracks, tires still hold air perfectly, about 21,000 miles on them, even wear pattern, good tread depth, many miles left in them > ADDITIONAL INFO: The trailer was always stored indoors when not in use which limited aging to the wheels and tires
You can contact us by filling in the form on the right hand column of the ad listing:
http://www.airstreamclassifieds.com/...els-and-tires/
