It’s possible. I would turn the pump back on, it will run briefly to pressurize the lines. If it stops within a second or two and remains off, you probably don’t have any leaks and your fine. If it does continue to run, see if you can quickly track down the leak. You can also turn the pump off and listen for the leak. (Be sure to turn of your HVAC and any other background noise) As you probably know now, don’t tow with your pump running. Create a pack up checklist, turning off the pump should be the last step before entering the tow vehicle.
I was in the habit of turning on the power and running the exhaust fans on my Chaparral boat to exhaust the engine compartment while towing to the lake 2 miles away. There was one time the captains chair loosened, then rotated and wedged into the drive trim down button on the throttle. Roughly 50 feet from the launch, my skeg was scraping a trench into the asphalt. You can’t make this stuff up. If it can happen...it will probably happen.
- Stewart
