01-29-2018, 03:36 PM
2018 16' Sport
Amesville
, Ohio
RV Hair Dryer
In my REAL camping days as a backpacker, I didn’t give a flying fig about my appearance. However, my recently acquired trailer will be used during work travel, so I have look presentable. The tricky part is I’ll be dry camping in expo center parking lots.
Has anyone found a decent 12v hair dryer that will blow my hair but not my fuses?
Thanks!!
01-29-2018, 03:45 PM
2007 22' International CCD
Corona
Google "12 volt DC Hair Dryer" for lots of choices to evaluate...
01-29-2018, 03:55 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
I've seen a few 12vDC dryers on Amazon. I even know someone who has one. But they say it's worse than useless for hair. They only use theirs to defrost their side windows on cold mornings. It's only rated for 220watts.
220w at 12vDC draws 18amps, compared to 1600w at 120vAC draws 13amps.
I think you would be better off using a 1600w 120vAC hair dryer powered through an inverter than using a 220w 12vDC dryer. But electrical is not really my field, so hopefully someone will double-check my numbers.
01-29-2018, 04:19 PM
Corona
Good point. I'm not even sure the wiring to the cigarette-lighter style plugs on an Airstream (and many new ones don't have them) has enough grunt to run 13-20 DC amps or more for a relatively wimpy hair dryer.
2000 watt Inverter plus big honking lithium battery bank and solar recharging covering the whole roof is the solution for running a real hair dryer, but it's going to be an issue dry camping.
I guess its an issue for styling, etc. I've never been accused of having 'style', I'm just handy with tools, radios, computers, and test equipment.
If I had any real hair left on my head, I could relate to this better. I'd say a quick trip to the nearest rest room with a purse-sized hair dryer might be an answer...
01-29-2018, 05:51 PM
2019 27' Flying Cloud
Kansas City
, Missouri
maybe consider an inverter plug, regular dryer, and use in the car with the engine running to power up.
Piggy Bank
01-29-2018, 05:52 PM
2009 34' Classic
Lake Worth Beach
Or use a generator for the 5 minutes you're drying your hair.
WBCCI 1433
🌴 Palm Beach County, FL 🌴
Silver Meteor - 2009 Airstream Classic Limited 34
2016 RAM 2500 Laramie Crew Cab 4x4, Cummins TurboDiesel
01-29-2018, 06:07 PM
Byron Center
, Michigan
Since you will be dry camping a lot, you might want some sort of small generator for emergencies. A Honda/Yamaha 2000-watt generator would do the trick, would be easy to move and store, and you wouldn't have to think twice about running even the largest home hair dryer with it. The generator should handle your a/c, too, on the hot days. Not simultaneously, but would give you the options.
I noticed that your tow vehicle was a Jeep, so hauling a gas generator will present some issues with fumes, etc. You might consider a propane conversion from Genconnex that you could run off of your existing propane tanks. They're good people with great customer service.
http://www.genconnexdirect.net/honda...g_packages.htm
02-27-2018, 10:28 AM
1988 32.5' Airstream 325
WhereIam
, Left Coast Proud
I use a normal hair dryer in our 1988 325 Classic Airstream Moho. I just don’t run anything else at the same time, and only use a single light.
03-01-2018, 05:48 AM
2010 27' FB Flying Cloud
Fraser Valley
, British Columbia
I just stick my head out the truck window and go fast.
Really fast.
