Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Rock Guards, Segment & Window Protectors
Old 07-19-2019, 11:48 AM   #1
1972 25' Tradewind
fort lauderdale , Florida
70's Rockguard plex replacement
Hello All,
I picked up a used rockguard for my 72 Tradewind but have to install new plexiglass/Acrylic.
I've seen a few posts on the subject but my questions are a little more specific.
The frame measures 1/4" so I'm assuming to use a piece of 1/4" thick plex, BUT, as per the attached pictures, where the vertical support rails are fastened to the frame, the rivets protrude into the track. The gap between edge of rivet and side of frame is 3/16". 3/16" thick plex seems to thin and I would think would rattle in the frame.
My thought was to use 1/4" plex and just mark and notch around the rivets. Thoughts?
Also, after installing the plex, I was thinking of running a bead of caulk on the backside all the way around the edge where the frame and plex meet...thinking this would keep the plex pushed forward.
Any pics of your rockguard or comments would be greatly appreciated.
Sorry about the pics, still having problems with orientaion
thank you
Eric
ID:	347064   Click image for larger version
ID:	347066   Click image for larger version
ehodg66 is offline   Reply With Quote
Rockguard - ROX-SOL GARD Zed2 Rock Guards, Segment & Window Protectors 5 05-02-2013 06:49 PM
plex glass john roeder Cleaning, Stripping & Polishing 10 04-07-2010 07:00 PM
Replacement Parts for Rockguard? tslanier Windows & Screens 2 07-15-2006 07:38 PM
Front Window Rockguard themartaman Windows & Screens 3 07-14-2002 11:01 AM
