Old 06-13-2021, 11:51 AM   #1
2011 27' FB Flying Cloud
Dunedin , Florida
Axle nut size question
Hi
Does anybody know the axle nut size on the axle
2011 flying cloud
speedyz4 is offline   Reply With Quote
Old 06-13-2021, 12:20 PM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Take a look at this reference from etrailer https://www.etrailer.com/Accessories...ine/6-183.html
Looks like size is 1" X 14 threads.
OOPS now I think you're looking for the socket size, right? Try 1 7/16"
GCinSC2 is offline   Reply With Quote
Old 06-15-2021, 07:32 AM   #3
2014 27' FB Eddie Bauer
Petaluma , California
Nut size
What was the answer? Mine is stamped 42 mm, does the drum come off once the nut is removed?
fireleu6169 is offline   Reply With Quote
Old 06-15-2021, 07:34 AM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Look for the snap ring….sealed bearings
Old 06-15-2021, 07:37 AM   #5
GCinSC2's Avatar
42mm is the size of the bearing bore.
Remove the dust cap, small snap ring, use 1 /7/16" by 1/2" drive, no extension, 1/2" breaker bar, possibly a cheater pipe and keep the socket tight up to the washer so it doesn't slip off.
Yes after the nut is removed the drum can slide off.
Gary
Old 06-15-2021, 01:11 PM   #6
Nuts
Thanks Gary, you are a Rock star
Old 06-15-2021, 02:12 PM   #7
GCinSC2's Avatar
Hope all works for you. I'm just a DIY'er that enjoys mechanical and electrical stuff.
Good luck
Old 06-16-2021, 09:28 AM   #8
Dunedin , Florida
Thank you all for your help
Have a great day
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
Picking up first Airstream tomorow axle nut question 386kustoms Axles 12 01-29-2011 08:11 AM
Lug nut size Whirlaway Wheels, Hubs & Bearings 4 04-17-2007 07:10 PM
Lug Nut Size?? Steve Heywood 1997 -2001 Excella 3 08-16-2005 12:24 PM
Lug Nut Size AYRSTRM2 Axles 0 08-17-2004 12:27 PM
