Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches > Hitches, Couplers & Balls
Old 02-21-2010, 12:55 PM   #1
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
Hitch on FRONT of tv for tight squeeze?
Here's my situation:
* 23' Safari lives in the backyard/driveway when not on the road
* only 6-8 inches clearance on each side between two fence posts, buried in concrete, not easily moved
* street-to-driveway incline too steep, I must use a ramp of four 2x12 x8foot timbers to avoid dragging bottom rear and hitch
Needless to say, re-storing the trailer from a trip is hairy and stressful. Takes me a few tense minutes to get her backed in properly with my wife or a neighbor spotting me on the blind side.
My bro in law comes over today and asks "why don't use just put a hitch on the front of your truck....would make it a whole lot easier to get in back there?"
hmmmm....why don't I?
Has anyone out in forums land ever done this with good results? It wouldn't have to be massive, WD, etc, right if you're only pushing the trailer 15 feet?
I'm curious..
fotochop is offline   Reply With Quote
Old 02-21-2010, 01:16 PM   #2
Images: 59
Ah, bro-in-law, probably the most useful guy in the world, right?
Not to discount his idea, but if you have really tight clearance on both sides, you might be better off sticking with the current method. If you are driving forward, your rear view mirrors become useless and they provided you with the widest possible view down the sides. If you are facing the trailer all you see is the front of the airstream, you can't see down the sides.
So if you're going forward, you will now need spotters on both sides. And now you have gone to all the trouble of unhitching and rehitching.
Also, depending on your tongue weight, tow vehicle, driveway surface and pitch, you could lose traction on the rear axle.
Old 02-21-2010, 01:29 PM   #3
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
I would try it. Im sure the tongue weight would compress those front springs enough to bring the butt up and you might not need as many boards for clearance. If the truck is 4x4 you could always engage that for extra traction. I have a tight driveway condition too so I use my jeep. Its a hassle but it is what it is..
Vin
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 02-21-2010, 01:37 PM   #4
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
I have a situation where my parking access is from a narrow alley, using a front trailer hitch makes getting in and out much less stressful. Having the hitch ball close to the steering wheels enables you to make sharp turns with a much narrower path. You can lean out the window and sight down the trailer curb side. Try it, pull up front to front to your trailer, and look out the window.
You are right, you don't need all the weight distribution stuff to go a short distance at a couple of mph. Also it's nice to know that you have it in case you get stuck someplace without enough room to turn around.
I installed a front receiver hitch, which I can also use for a bicycle rack when we take the bikes along.
snake is offline   Reply With Quote
Old 02-21-2010, 02:00 PM   #5
fotochop's Avatar
1969 23' Safari
Images: 18
thanks...food for thought indeed...
snake: I like the receiver hitch idea doubling as bike rack.. did you d.i.y. it or have a shop do the installation? (not sure I trust the local U-Haul people to do it correctly....I'm open to recommendations..)
mark: I hadn't considered the visibility issues, thanks for that...seems like visibility will be dependent on whether I'm turning right or left (if left I could imagine the "lean out the window" may work on drivers side, if right, you're right, I'm probably blind on both sides..)
slide: truck is Tundra 2wd, not sure if there would be traction issues...I doubt it, driveway isnt radical just too steep not to drag...
Old 02-21-2010, 02:53 PM   #6
Cantrell's Avatar
1985 34' Limited
1960 24' Tradewind
Summerville , South Carolina
Interesting Thread
This might work for my situation, too. Our 34 lives in a 11'3" wide space that is entered at a 90 degree angle from a 30' wide concrete pad (photo below). A front mount hitch would surely make this stunt easier as there is literally an inch of clearance on either side as it enters the hole.
To those who have a front mounted hitch: Does it mount below the lowest part of the front of the truck (in my case a plastic air dam)? Are there any hangup issues with the lower clearance (grabbing curbs, angled drives, etc.)?
I have a 2005 F150 supercrew--non 4x4--there is 11.5 inches of clearance between the ground and the lowest point of the front of the truck.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 02-21-2010, 03:16 PM   #7
Kevin245's Avatar
A front hitch will work fine but the handling characteristics are different and you'll definitely need a spotter.
Here's a thread on the topic.
http://www.airforums.com/forums/f464...hlight=spotter
Regards,
Kevin
William C. Swinney
Old 02-21-2010, 03:22 PM   #8
moderator
Airslide's Avatar
Wilton , California
Images: 50
Bill,
That is a very good looking trailer and great spot for her.
Here is an example of how tucked away the hitch can be.
Vinnie
Old 02-21-2010, 03:34 PM   #9
1972 25' Tradewind
McHenry County , Illinois
In the past I put a receiver on the front of an F-150 and it worked great stuffing the trailer up close to the garage. My old man had one on his ’62 Plymouth to stuff ours into the "perfect" spot when I was a kid.
Does yours have the front tow hooks? My Expy does and it looks like a plausible place to begin mount the receiver and bring it out from the bumper cover. The weight of that 34 will probably drop the axle down to the stops. Might have to take the cover off and cut an access hole. Easy to do for any hitch shop.
If you want to get creative I once saw a GMC van with one hidden behind the front license plate.
I wouldn’t hesitate to recommend a front hitch to anyone who has to thread the needle from time to time. I never found a need for a spotter with the smaller rigs I've had. Maybe just lucky.
Good luck,
Tom.
Tom Nugler is offline   Reply With Quote
Old 02-21-2010, 04:50 PM   #10
snake's Avatar
1994 21' Sovereign
Tucson , Arizona
Rick: I installed the front hitch myself, pretty simple. Yours is a common truck, you shouldn't have a problem finding a bolt-up one from any of the manufacturers. do a Google search for 'front trailer hitch"
I haven't had too much of a problem with right turns, after you've started your turn you can see the inside side of the trailer. Of course, whatever way you are turning a trailer there is a blind side, with a front or rear hitch.
Old 02-21-2010, 05:00 PM   #11
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
I'm curious..
I put a hitch on the front of my truck to park my trailer in my backyard. I do need spotters when parking. However you do have much better maneauvering.
ID:	96667   Click image for larger version
Michelle TAC MT-0
Sarah, Snowball
Old 02-21-2010, 05:03 PM   #12
gsmithii's Avatar
2013 30' Flying Cloud
Virginia Beach , Virginia
Boaters use a front hitch to maneuver their boat in tight quarters. If you know any boaters who could comment they could be a resource. Living here in a beach area we see front hitches all the time - for boaters.
Skip
Speed is Life . . . guidance is optional . . .
The Traveling Circus: 2013 Flying Cloud 30A; 2006 Chevy Duramax Crew/LWB
Air #42313 TAC VA-7 WBCCI #1290
gsmithii is offline   Reply With Quote
Old 02-21-2010, 05:29 PM   #13
tkowalyk's Avatar
2013 27' FB Classic
Clermont , Florida
Images: 11
What about something like this -- there are several different manufacturers
Powrhitch Trailer Mover
Tom & Lori
2013 27 FB Classic Limited
2019 Ford F250 King Ranch 6.7L Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 02-21-2010, 05:32 PM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
Fotochop
I would consider 6-8" per side to be a huge amount of room if going straight back. Sure you have to be careful but still.
Most people with front hitches use them because they have to maneuver around a corner and steering the tongue is a necessity. They also work well with smaller trailers where the problem with a rear hitch is that you can't see the trailer and don't know what it's doing. And they provide better visibility when the trailer is at an angle and outside the field of view of the mirrors.
The hassle of rehitching has to be considered.
Not sure that they'd help much with a 'stream. I don't know what your site situation is exactly but you might be money ahead and have less hassle having your local bobcat operator come out and do some grading to get rid of the dip and pull up the fenceposts, compared to the cost of a front hitch. Someone who's good with a bobcat can get a lot done in half a day.
If you go the front hitch route, you really do have to think through what you can see. There are front hitches made for most trucks, not sure about the Tundra. I would be concerned about traction with the weight on the front wheels.
Old 02-21-2010, 06:17 PM   #15
nilesrob's Avatar
Hampton , New Hampshire
Images: 12
We added a front hitch several years ago on our X, more for additional carrying power as opposed to manuevering. Either way, it was very useful. On the X, we had to forego the fog lights in order to install the front hitch, but that was not a big sacrifice.
Name:	IMG_0183 (Small).JPG
Brad (The Slowsky's)
2019 Airstream Classic 30RBT, 2021 Ford F350 King Ranch 4X4 w/6.7L Diesel, Hensley, ACI #1313
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 02-21-2010, 06:31 PM   #16
moderator
Airslide's Avatar
Wilton , California
Images: 50
Brad,
Are there any problems with overheating on long grades? It would seem that with that large generator blocking the radiator there might be a concern.
Looks like a good solution otherwise for additional carrying capacity.
Vin
Old 02-21-2010, 06:43 PM   #17
nilesrob's Avatar
Images: 12
We never had a problem; temperature gauge never raised, and we (in this case) had traveled thousands of miles (to/from Big Bend NP in TX). Similarly, we did the same thing to/from ATL to Death Valley - zero issues. Not saying it is right for everyone, but it worked great for us.
We did not always travel with a generator - just a picture by way of example. We also traveled with bikes on the front, which was great - and BTW did not block our visibility.
Old 02-21-2010, 06:47 PM   #18
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
A front hitch on the front of my pickup was a breeze....with the tent trailer we had a while ago. It works great now for my utility traile, I can turn the trailer on a dime. BUT for one the front hitch isn't beefy enough for our Trade Wind. I might have a receiver installed. I am concerned tho about visablity.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-21-2010, 06:57 PM   #19
moderator
Airslide's Avatar
Wilton , California
Images: 50
Brad,
Sounds good. Im sure you kept an eye on it. One thing to consider. With todays vehicles you dont always get the right information regarding engine temp. Often the manufactures dampen the readings so it doesnt alarm the driver (kinda defeats the purpose of the guages).
For example pulling a hard grade and then taking an offramp. The temp on an older car would climb as the waterpump is now turning slower and less airflow is passing the radiator. This is just a normal scenero of when the guage would climb. Because this is so alarming they now stick the guage at half and let it all work itself out with auxilary cooling fans ect..
I would just keep the air conditioning off when climbing grades if I had that generator upfront and it should be ok. Thats a heavy trailer!
Vinnie
Old 02-21-2010, 07:40 PM   #20
FreshAir's Avatar
1966 24' Tradewind
Neil.
BTW a while ago I noticed a receiver hitch mounted to the right side of the front of a pickup. This would allow the driver to 'see' down the right side of his trailer. Of course this would add width to the trailer truck combo but if one 'knows' his/her trailer parking place this may be an idea worth considering.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Front End Hitch centennialman Hitches, Couplers & Balls 14 01-13-2018 09:42 PM
anyone squeeze a family of 4 in a smaller trailer? karendee Buyer Guidelines 16 06-02-2010 02:42 PM
Front hitch woppa 4 Hitches, Couplers & Balls 22 07-12-2009 10:29 PM
HELP!!! On a tight schedule, need to replace floor from front to rear... JeepinAudiophile Repairing/Replacing Floor &/or Frame 73 06-21-2008 10:34 AM
WSJ - Economy Puts Tight Squeeze on RV Makers munimula Dollars & Cents 17 05-13-2008 07:17 PM
