Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electronics & Connectivity > Audio, Video & TV
Old 08-21-2007, 04:30 PM   #1
Wayward's Avatar
Broadway , North Carolina
USB Input available with Audio/Video Upgrade package
Looking to feed internet radio from my laptop into the Safari's sound system, I read posts where folks added a Sony XA-300 (has USB input) to their Sony CD player, gaining additional audio inputs. For those of you with Airstream's Audio/Video upgrade package, you probably have an XA-300 already.
I found the XA-300 buried behind the access panel to the Sony headunit. For some reason, Airstream decided to not bring out the USB jack. I plugged a standard USB cable into the XA-300 and ran it out the same hole as the CD changer cable. My laptop immediately recognized it as "USB Speakers" and all I had to do is select the source on the headunit as CDC4=USB.
btw, if you've not listened to Pandora, it is worth a look. You create you own "radio stations". By asking you to seed the station with a song or artist, Pandora helps you figure out what type music you like and then keeps streaming great songs.
Pandora Radio - Listen to Free Internet Radio, Find New Music
2006 Safari SE FB
2000 F150 4.2L (retired), 2011 F250 6.2L, 2010 ML550, 2000 Excursion 7.3L
Broadway, NC
Old 08-02-2010, 09:34 AM   #2
Wayward's Avatar
selecting USB Speakers as Windows output sound device
It seems that when using a Windows laptop to play audio into the Sony via USB, the audio device should be selected before starting up the audio application. e.g. when using a browser to play Pandora, I select USB Speakers first, then start Firefox browser.
I found a simple application that makes switching audio output devices easier in Windows and sits in the system tray.
Quick Sound Switch
2006 Safari SE FB
Broadway, NC
Old 08-02-2010, 10:06 AM   #3
Ag&Au's Avatar
Port Orchard , Washington
Thanks For the information, I will have to mess around with that and see what I can do with it.
Regards,
Ken
Old 04-27-2013, 07:57 PM   #4
2007 31' Classic
Leavenworth , Kansas
Adding a Bluray Player?
Hello, Thanks for your post on this adapter to add other input into the stereo. I have a 2007 31' classic with the same stereo setup you described. I've considered removing the CD changer in favor of the USB line in for MP3 player and possibly a bluray player in the place where the changer currently sits. I was thinking that if I added it in that cabinet, I could plug the audio directly into the stereo-- but routing the HDMI cable to the TV might be a chore. I'm curious if anyone had tried adding a bluray player into this stereo system in this way.
Any suggestions out there?
Steve
sandtwalker is offline   Reply With Quote
Old 04-30-2013, 05:39 PM   #5
Dyoung59's Avatar
1979 25' Tradewind
New Bern , North Carolina
Can you use a regular tv or do I have to purchase a 12 volt tv for my 79Trade wind.
Dyoung59 is offline   Reply With Quote
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
SAFETY : >>>>Lightning Strikes<<<< hex Our Community 36 12-18-2005 11:34 AM
Important upgrade - Cap Puller Janet H Exterior Restoration Forum 9 04-18-2004 05:45 AM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Photos on the Portal Page. WE NEED YOUR INPUT! Vote please! Andy R Our Community 6 10-25-2002 08:55 AM
