Old 02-08-2019, 09:57 AM   #21
2017 19' Flying Cloud
Palm Springs , California
Batteries draining
Well I learned a lot. Thanks for all the replies.
Paulinekeogh is offline   Reply With Quote
Old 02-08-2019, 10:36 AM   #22
bwpaint's Avatar
2015 25' FB International
my , house
Hi- I also had to disconnect neg to the inverter. Solved my problem. Currently mine have been disconnected for about 3 weeks and still at 12.78v.
bwpaint is offline   Reply With Quote
Old 02-08-2019, 11:32 AM   #23
Sag Harbor , New York
Please let us know what you figure the cause was. We all learn from this process.
Good luck,
Peter
Old 02-09-2019, 11:08 AM   #24
Why are my batteries draining when parked
Thanks v much Tim. I don’t know what you mean referring to “new Airstream battery chargers“ - I will look into and follow your advice. One question, at home, if I plug into home shore power, should I switch to “in use” instead of “store” , to ensure the batteries charge ? And leave it that way?
I will have to get a solar panel installed on the roof I think. It’s a bit unsightly having the unit plugged in in my front driveway, with a long orange cord going to the outside power sockets.
Much obliged. Pauline.
Old 02-09-2019, 01:26 PM   #25
Wolfwhistle
Fair_Enough's Avatar
Margaritaville , Banana Republic
I’m not Tim, but what he means by new charger is that older Trailers have a single stage converter/charger (my 2013 was like that). JC is now installing multi-stage converter/ chargers. I upgraded to the PD4655VL which is also LFP ready. The other thing is for the batteries to be charged mine had to be in “Use” mode. In “Store” the battery is partially disconnected. The infamous CO detector will drain the batteries given enough time and is still running in “Store” mode. I added a battery cutoff switch so I can totally disconnect the batteries. One thing that happened to me on an SOB, was I left a light on in a storage compartment that ran mine down. Another thing that will quickly run a battery down is if the breakaway switch gets activated. Clint
Is taking it all with you, really getting away from it all?
Fair_Enough is offline   Reply With Quote
New 2014 Sport 16' - why are the running lights blinking when parked? OurJuneBug Airstream Trailer Forums 3 02-08-2019 10:10 AM
Tire Care while parked winter storage wimpy Classic Motorhomes 2 03-13-2018 01:38 PM
Why are my batteries draining while on shore power Ridget Electrical - Systems, Generators, Batteries & Solar 6 08-30-2017 05:08 AM
Ventilation while parked/not in use GinaNBob General Motorhome Topics 27 06-24-2016 08:07 PM
Charging with the Truck while parked?? DJW Electrical - Systems, Generators, Batteries & Solar 30 07-19-2015 06:27 PM
