06-13-2009, 11:29 PM
1988 34.5' Airstream 345
Denver
Univolt TU-345A Humming
I think its the original and it seems to works good, but humms loud. I have a 1972 Trade Wind. I pulled it out because I'm redoing the bathroom, but don't want to reinstall it if its a concern. A local repair shop said humming is common, but the more opinions the better.
06-14-2009, 01:12 AM
Corona
The humming, is caused by loose laminations in the transformer, that's in the Univolt.
If you have plenty of time, you can repot the transformer, which will cure the hum.
If you want to know how to repot it, let me know.
06-14-2009, 04:02 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Yup...humming is common, so common in fact many people installed switches to turn them off at night Unless you are bent on a perfect restoration I would consider an upgrade to something like the Intelipower. Technology marches on and the Uni-volt is one piece of old technology I can do with out. The newer ones are solid state, quieter and are better for your batteries.
Aaron
WBCCI #XXXX AIR #2495
06-14-2009, 07:07 AM
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay
, Oklahoma
They hum, and boil batteries dry, if your not careful and watch the water level in the battery. We opted for an upgrade to a modern charger/converter and found it worth the expense.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
06-14-2009, 09:15 AM
Denver
Thanks Andy I would be curious about the repot. Please let me know.
Cody
06-14-2009, 09:19 AM
Denver
Aaron,
Thanks I'll look into the intelipower. I did by a new better battery so thats a concern as well.
06-14-2009, 11:48 AM
Vagabond
1973 31' Sovereign
Fort Meade Md. RV park slot 8!!
, Motorsports Photographer
The truth of Its, I have been staying In my 73 a lot after the fire In the 91.. I have come to the conclusion I missss that buzzzing on my afternoon naps especial In a noise campgrounds!! In the 91 I always have music or a fan on for background noise all the time. In the 73 no need It has Its own (BUZZ)!!!!
DIMMER
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
06-14-2009, 01:38 PM
1984 31' Airstream310
Ajo
Mine hums, never trashed a battery since I went to sealed ones. I just shut down the GFI when we hit the hay.
06-14-2009, 03:38 PM
Corona
Cody
Cody.
Remove the transformer.
Soak it for a couple of days, and rotate it every few hours.
The liguid is simple varnish.
After acouple of days, remove the transformer and let it air dry for a couple of days.
Then reinstall it.
The hum will be gone.
And it's a lot cheaper than a new Univolt, regardless of brand.
06-16-2009, 10:02 AM
Denver
Andy THANKS I'll do that... Which one is the transformer? What should I soak it in?
06-16-2009, 11:01 AM
Corona
Take the cover off the univilt.
You will see the transformer.
Write down which wire goes to whatever.
Check post #10 above for instructions as to how to do it.
VARNISH is the potting material.
06-29-2009, 01:45 PM
Denver
Andy,
I went to take the Univolt apart this weekend and noticed the cover was riveted together. Should I just drill them out?
06-29-2009, 02:08 PM
Corona
Andy,
Just drill them out and remove the cover.
There is nothing you can hurt by doing that.
06-29-2009, 02:45 PM
Denver
Sounds good and thanks again for the help. I'll do it and take a picture before I start pulling wires. I'll post the pics by the end of the day tomorrow.
06-29-2009, 06:57 PM
Denver
Ok so I romoved the cover. This thing looks old, but Im up to giving it a shot. Now which on(s) is the transformer? Most of it is saudered together.
06-29-2009, 07:10 PM
Denver
Ok Andy so I took off the cover and this thing looks OLD!!! But Im up to giving this a shot. Now which one is the transformer or transformers. Most of it is saudered together.
06-29-2009, 09:35 PM
Corona
The part that is at the very left of your photo, is the transformer, that may be in a box.
06-30-2009, 01:05 PM
Denver
Andy,
It looks almost impossible to remove without taking the entire thing apart and even then I think it might be adhered to to cover in some way as I think it was originally like that because of the heat factor. What if I were to do this? I can leave it assembled and stand it upright in a bucket with the transformer at the bottom. I can then fill the bucket with varnish to the point on it being emerged without getting to the other components. Leave it that way for several days then let it dry out. I wont be able to rotate it, but if it is completely emerged and soaking for a few days maybe it will get there. Ill also let it dry for a few weeks and keep it in the sun so it will evaporate as much as possible. One other question. With varnish being flammable and an inverter getting hot should I be concerned for on down the road when its hooked up?
06-30-2009, 02:48 PM
Corona
Andy,
Your transformer is already potted and encased.
The repotting can only take place with the actual transformer, without any covers or encasing.
Varnish has been used to pot transformers, for as long as varnish has been around.
I don't have any other suggestions for you to try, other than creating a sound barrier.
06-30-2009, 04:17 PM
Denver
Andy,
Thanks again for the help. I just went back into the garage and looked at it again the tan stuff in the picture above almost like stiro-foam is literally glued to the metal box around it. The only way I see to get it off is to chisel at it which probably is not a good idea. Maybe its best to leave it alone if my idea would not work, or buy a new one.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
univolt humming
slvrbulit |
Batteries, Univolts, Converters & Inverters |
5 |
04-23-2009 07:04 AM |
Brakes humming
msmst25 |
Brakes & Brake Controllers |
4 |
08-19-2008 06:28 PM |
Humming Univolt
Holland |
Electrical - Systems, Generators, Batteries & Solar |
11 |
01-26-2006 10:27 AM |
Univolt HUMMING!
markparker22 |
18 |
10-12-2004 10:44 AM |
Univolt - its warm but humming!
Bryanhu |
2 |
04-03-2004 06:30 PM |
