Originally Posted by WherryWillie
A question that relates here please. There are two batteries. Obviously you are leaving them connected. Where do you clamp the charger: on one battery or positive on one and negative on the other? And if both, there are two possible configurations does it matter which?
Will AS ever get this right? I’ve sailed for years on boats with the same basic requirements: 12v at sea and 120v shore power. It is not a topic of discussion because they work.
Hi
Simple answer: Don't worry about it. Your charger isn't putting out all that much current. Clamp the negative any place that's convenient as a solid ground ( battery terminals, either one, are a good bet ). Clamp the positive on the +12 terminal on either battery or on some other upstream battery connection if that is easier to get to.
The only thing to watch is getting a solid connection. Clamping on to a pile of rust / dirt / corrosion is not a great approach. Solid does not mean attaching your 30A charger to a piece of number 10 (or less) wire. The solid connections in an AS are all number 6 or larger.
If you happen to have a 200A charger then the drill is s bit different. Since most folks don't have one, it's not worth diving into. On the other end, if you are playing with a 1.25A trickle charger ... that number 10 wire may be just fine.
