Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Batteries, Univolts, Converters & Inverters
Old 01-12-2019, 10:03 AM   #1
kkdesigns's Avatar
2018 28' Tommy Bahama
atlanta , GA
Inverter outlets not working attached to shore power
Hey gang. Hoping someone can answer this for me.
I have a 2018 Tommy Bahama and am having a problem I haven't run into before.
I'm am staying in an rv park in houston for a bit. I'm full hookup.
The issue I'm having is that all the outlets that are connected to the inverter, including the TV outlets front and back are not getting power unless the remote inverter switch is turned on. Never had this issue before. I was watching TV and it just shut off. My computer was plugged into a different inverter outlet and it wasn't charging. These are all outlets connected to the inverter. As soon as I turned the inverter remote switch on, everything powered up. I shouldn't need to do this hooked to shore power.
Any guesses as to what this issue might be or where to start looking?
Thanks in advance for your help..
Kyle
2015 ford F 350
2018 Tommy Bahama 27FB
follow us on RVHive.com
kkdesigns is offline   Reply With Quote
Old 01-12-2019, 10:05 AM   #2
Opinionated newb...
wave man's Avatar
2018 25' Flying Cloud
League City , TX
Check the fuses first...
Men are but men, and the greatest men are they who soonest learn the simpler things. ROBERT E. HOWARD
What a man does for pay is of little significance. What he is, as a sensitive instrument responsive to the world's beauty, is everything! H. P. Lovecraft
wave man is offline   Reply With Quote
Old 01-12-2019, 10:13 AM   #3
kkdesigns's Avatar
atlanta , GA
Yes, I should have mentioned this is on a breaker which I checked first. It wasn't tripped. I turned it off and on. I also unhooked shore power and turned everything off and cycled the battery disconnect. Still not working without haveing the remote inverter switch powered.
2015 ford F 350
Old 01-12-2019, 10:28 AM   #4
pjshier's Avatar
2017 27' International
Wasilla , Alaska
If you are on shore power, why use the inverter outlets? Unless there is some reason, swap the computer and TV to the 110 shore power outlets and don't use the inverter. Unless I have my terminology confused - the inverter should be for "inverting" 12 volt DC battery power into 110AC, right?
2017 Int'l Serenity 27FB
2020 F250 powered by converted solar
pjshier is offline   Reply With Quote
Old 01-12-2019, 10:52 AM   #5
kkdesigns's Avatar
atlanta , GA
The outlets should work when plugged into shorepower without the inverter being on. This is how they have worked since I got it. They will also worked when a generator is on. You should only need to have inverter switch turned on when you are running off straight battery power.
2015 ford F 350
Old 01-12-2019, 10:57 AM   #6
LDM
2024 27' Globetrotter
Jonesville , Louisiana
Be sure the inverter has 110ac to it.
LDM is offline   Reply With Quote
Old 01-12-2019, 11:10 AM   #7
LDM
I had wire break where it went into inverter on SOB. You are right about the way it works.
Old 01-12-2019, 11:14 AM   #8
Trailer Sold, Waving
Acheron2010's Avatar
2019 26' Flying Cloud
Stettler , Alberta
Just for grins, check the GFCI button on one of the outlets. That was the source of my 120V mystery in my 2019 FC.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 01-12-2019, 11:25 AM   #9
kkdesigns's Avatar
atlanta , GA
Just some more info, the light on the top of the inverter which should be green, is yellow which indicates battery back up status, even though it is plugged in.
2015 ford F 350
Old 01-12-2019, 11:27 AM   #10
kkdesigns's Avatar
atlanta , GA
yep, first step on trouble shoot, along with breakers and fuses.
Learned this in the bathroom at the house. Ha
2015 ford F 350
Old 01-12-2019, 12:44 PM   #11
Dave-n-Janet's Avatar
Moss Point , Mississippi
Use a volt meter or some other means to confirm you have 110v going to the outlet the inverter is plugged into. If yes, then maybe internal fusing on inverter, otherwise may be time to replace inverter.
Dave-n-Janet is offline   Reply With Quote
Old 01-12-2019, 01:36 PM   #12
Adventure.AS's Avatar
2017 25' International
Niagara-on-the-Lake , ON Canada
Newer Airstreams don’t have separate inverter circuits but a pass through system.
Ray B.
Adventure.AS is offline   Reply With Quote
Old 01-12-2019, 01:47 PM   #13
Stettler , Alberta
My 2019 Flying Cloud has an inverter circuit and a shore power circuit. Outlets by stove and bed and bath are not from inverter, for example.
WBCCI #6679
Old 01-12-2019, 04:22 PM   #14
Do you have two outlets by the TV for example, or just the one?
Ray B.
Old 01-12-2019, 06:35 PM   #15
pjshier's Avatar
Wasilla , Alaska
Thx. I learned something today. New guy here who has a 2017 with separate plug-ins and a need to swap plugs and activate inverter when boondocking; swap back when on shore. 2018 must have pass-thru single plug-ins for both.
Old 01-13-2019, 10:44 AM   #16
1985 31' Excella
st. Paul , mn
1st off more info , is the inverter original equipment - and what make & model ?
Then how is it wired into the trailer ?
I haven't worked on an Airstream that had an inverter from factory , so not sure how it is being used .
I build alternative energy systems , mostly solar and even repair inverters .
Some have transfer switches and passthrough when AC - either shore or generator .
But with info provided [ have to assume some issues ] it sounds like your operating the same as the past & things have changed , then you mention yellow light , so battery or connection issue .
Get a multimeter and check & list all voltages in & out of the inverter ?
85 Excella , 31' , electric brakes , R. twin [ would like it to be a single ] , future upgrades , composting toilet [ replace black water tank with a 2nd fresh ] , solar power , instant hot water heater .
Tow 94 Dodge Ram , 4x4 , Cummins , AT .
JohnTF is offline   Reply With Quote
Old 01-13-2019, 11:01 AM   #17
journeydog's Avatar
Silver City , New Mexico
FWIW - I have the same issue/same model AS ('18 Tommy).
(Maybe Alfred-the-new-guy was assigned to wire these puppies while Susie-the-master-electrician was on vac?) My Tommy was working as it should - not requiring inverter on while "plugged in" - but, started this "inverter-on requirement" suddenly one day while trying to get TV to work and still "plugged in" to shore power. The other outlets seemed to be OK (not needing inverter on). The factory-provided wiring docs say the TVs are getting their power from the inverter. Why then, do the TVs work when most of the time the inverter switch is off?
All I can say is that ït's magic - WTF?
YIKES!!
Class A Safari Trek 2830 - SOLD; TC Lance 1010 - SOLD;
TT Arctic Fox 30U - SOLD; TT Forest River Mini - SOLD;
Class B+ Pleasure Way P
ursuit - FS; $$$$ - GONE
If it ain't broke I can break it
A dime still makes a pretty good screwdriver
journeydog is offline   Reply With Quote
Old 01-13-2019, 11:32 AM   #18
Stay CazuaL
cazual6's Avatar
2014 19' Flying Cloud
Reseda , California
I don't know which one is yours, but my old 2014 had two outlets side by side. One was marked BLUE which means an inverter outlet.
My newer 2018 only has one outlet.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
WBCCI 9164
*Virtual campfire at https://www.facebook.com/groups/Airs...dictsforAdults
cazual6 is offline   Reply With Quote
Old 01-13-2019, 01:51 PM   #19
Rainmaker's Avatar
2018 26' Flying Cloud
Hanover , Pennsylvania
Hopefully by now you have found the answer to your problem. What I found when I had that happen in our AS, is the inverter had become unplugged. None the receptacles on that circuit worked from normal 120v shore power. Plugged it back in and everything worked fine since.
Rainmaker is offline   Reply With Quote
Old 01-13-2019, 07:32 PM   #20
DNM
Madison , South Dakota
There is a 15 amp circuit breaker on top of the inverter if it is tripped you get no pass through power to TV outlets. They are not connected through the 110 breaker panel
DNM is offline   Reply With Quote
Best way to wire inverter/converter/shore power for seamless AC power justgoclimb Batteries, Univolts, Converters & Inverters 39 06-28-2017 04:51 PM
Shore power not working ?? mrcolin2u Electrical - Systems, Generators, Batteries & Solar 3 06-29-2016 08:46 PM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
Inverter outlets not working FinnSwede Batteries, Univolts, Converters & Inverters 10 11-16-2011 03:14 PM
