Adding batteries
We have a 2017 30 classic, it has the factory solar and a previous owner added two more 90 watt panels and two 6v crown 220 AH batteries. The work was done by an AS dealer. We want to add two more batteries and change the factory converter. Should we add another battery brand as there is no Crown dealer here? Which converter should we use? Does the factory solar charge controller do a good job, does anyone know its specs etc.? The local AS dealer will do the work and install the two new batteries under the couch leaving the others outside in the box.
