07-27-2013, 09:20 PM
tracker
1969 23' Safari
crescent city
LEDs vs Incandescent
I would like to hear the pros and cons of replacing original incandescent clearance and brake/tail lights with leds. are they realy that much brighter? Any other reasons?
07-27-2013, 09:40 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
The LEDs are brighter and the brake LEDs will actually illuminate quicker. However, turn indicator LEDs may need a resistor added to blink correctly.
07-27-2013, 09:45 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
LEDs last years longer as well.
07-28-2013, 12:37 AM
USN/LAPD Retired
North Las Vegas
, United States
LET Upgrade
Ok, check out the below Youtube vid on LED's for RV's ...
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
07-28-2013, 02:07 AM
1988 Argosy 32
Lomita
you can skip being given a fix it ticket for haveing a burned out light bulb.
07-28-2013, 05:29 AM
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
LED brake lights seem to show up brighter when the sun is on the tail end of your trailer and illuminate a split second quicker thus the reason we installed them a few years back.
In dog years, I'm dead!
07-28-2013, 06:20 AM
Retired.
, At Large
They also draw less power, so the trailer lights are less of a burden on your tow vehicle's electrical system.
07-28-2013, 06:32 AM
1999 25' Safari
Denver
Having changed out to LED'S on the outside a few years ago, the backup lights are 10 times brighter than the inc bulbs that were in there to begin with. Jim
Jim D.
AIR # 56543 TAC# CO-10
07-28-2013, 11:04 AM
Fenton
, Missouri
Same reason why I replaced mine when these became available. I've followed too many trailers whose tail lights get wiped out by the trailing afternoon sun.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-28-2013, 11:30 AM
1988 32' Excella
Robbinsville
, New Jersey
That's why I want my father to replace his. When I was towing his trailer for several hours with the headlights on the light switch in his truck was very hot.
Some newer vehicles have a relay for the headlight and/or for a separate circuit for trailer lights and shouldn't have this problem.
11-18-2013, 05:07 AM
1977 31' Sovereign
Atlanta
, Georgia
I'm honestly still thinking about this topic from a cost / benefit approach. While I agree that LED are better when you weigh the costs of bulb and resistors against more commonly replaced components I think at least for the exterior I'll stay with traditional but keep some extra bulbs in my bag.
"The road goes on forever and the party never ends" - R.E.Keen
11-18-2013, 05:31 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
X2
Replaced all high use interior, scare & step lights with LED, (for battery conservation) + all our flashlights.
Classic 10yrs, Burb 7yrs...nothing burnt out yet.
11-18-2013, 05:53 AM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
What Bob said. The difference in battery life when boondocking can be seen (Literally). Also, in very hot climates the LED's don't heat up the trailer. The in ceiling lights I used to have in my 2005 were HOT HOT HOT.
I also have not yet burned out a LED emitter and I had some that were over two years old in the 2005.
Paula
11-18-2013, 06:51 AM
Denton
, North Carolina
My take on the matter for tail lights
LED Cluster Bulbs in STT lights
I'm often asked what bulb should be used for an an existing STT (Stop Tail and Turn) light which has an 1157 bulb in it. My answer is always, "there aren't any". In a rare situation a cluster bulb will work and give good light out-put, but that is the acceptation and not the rule.
Primarily, the reason why someone wants to use LEDs on the outside of any vehicle is safety. The reason why they are safer is two fold. If the light is designed correctly the result is more light and thus you are more visible on the road. That is not to say that your lights should be so bright that you are a hazard, by blinding your fellow travelers, but just enough for you have good visibility when you are turning or stopping. The other reason why LEDs are a good choice is it takes many of them to make up the amount of light that is needed. If you have a failure you still have lots of light. In an incandescent bulb you have one filament and if you have a failure you have NO light.
One of the main reasons why cluster bulbs don't work well is they product about 1/3 as much light if the cluster bulb is about the same size as the incandescent bulb your replacing. The other reason is most of the STT fixtures are designed to refract and reflect light from one single location.
Below are two pictures which have a STT light and some markings that illustrate what happens when you use a cluster bulb in some STT lights.
The little blue marks on the red lens are to show how the lens is designed to refract light.
On the next picture ( below) is what a cluster bulb looks like ( as crude as it is :-) in the same light fixture.
Many points of light being refracted and reflected has a result of the light going in many different directions. In the event that your cluster bulb was to produce more light (they seldom do) than the incandescent bulb, it would not be as effective ( and safe) because the light does not all show up at the intended target, the guy behind you.
One of the first projects LED4RV started was finding a fix for the 4.25 Monarch tail light. ( pictured above). We had so many people contact us who wanted a brighter light. They did not care if it was LED or not. They just wanted greater visibility on the road at night. One guy called us and he said he was going to find a fix or sell his Airstream. At the time we had a large red pad LED-kit1 that glued onto the lens. It worked very well and did make folks safer while on their travels.
As a rule of thumb, LED pads (which have all the LEDs facing outward) give more light and are a much better choice. If you notice, all the new cars have a pad style set-up that point in the same direction and thus they give more light.
The purpose of this blog post is not to promote the kit as much as it is to steer folks in the right direction, of what to look for, when trying to retrofit their older units with LED light.
For the marker/running lights it is the same. Changing the whole light fixture and not the bulb is the smart way to go.
Dan Brown Denton NC
11-18-2013, 07:21 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Dan....you know I'm a loyal customer...but.
Put an led bulb the same color as the lens and it will be considerably brighter.
11-18-2013, 08:36 AM
Denton
, North Carolina
red on red
Red LED cluster bulb thru a Red Lens will be more than the Bright white cluster bulb, but I have not found any that would give more light than the pad. Even on some of the "aluminum base high intensity" cluster bulbs.
Dan Brown Denton NC
11-18-2013, 01:27 PM
1981 31' Excella II
New Market
, Alabama
Would not a red flat round array stuck to the inside of the red lens work better than trying to utilize the stock reflector and an LED bulb? I have seen these on truck tail light so they must be available. The individual LED's are already optimized in one direction.
I looked for something like this on ebay the other day and never found something to my liking.
Perry
11-18-2013, 01:51 PM
1993 34' Excella
Estancia
, New Mexico
IMHO
The Pros:
LEDS are brighter especially for running lights and tail/ signal lights.
LEDS use a lot less juice and are better for boondocking.
The Cons:
Much more expensive
May need to be fabricated for the purpose which needs some techy knowledge
The rest of the story:
If your incandescent bulbs are burning out quickly something is wrong. 12 v incandescent light bulbs last for years.
I have never heard of a problem from incandescent bulbs causing any problems for the Tow Vehicle.
11-18-2013, 09:22 PM
Denton
, North Carolina
arrays are better
Perry
For sure, Arrays and Pads, put out more light than cluster bulbs, in the Stop Tail and Turn setup. Arrays/pads are available for everything Airstream made from 1965 to present. And also in some earlier years than that.
Dan Brown Denton NC
11-18-2013, 09:52 PM
Salem
, Oregon
Hi, my trailer came with LED tail lights and they started to fail after about three years; My replacements have been working flawlessly for over six years and cost about 1/3rd the factory price. I replaced my porch light with an LED that is bright and won't melt the lens. Since I seldom ever boondock, the only LED's that I have inside of my trailer are (4) battery powered puck lights. I plan to replace my step light with an LED in the future. [soon as I find the right one]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
