Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 01-16-2022, 08:47 PM   #1
2022 28' Pottery Barn
Las Vegas , Nevada
How to remove ceiling lights and fix noise when AC/heat pump is on
Hello fellow airstreamers, one of my ceiling lights makes annoying noises anytime when the roof is vibrating caused by AC/heat pump.
Sometime the noise will be gone if I twist the light a little to make it fits tighter. But almost every time, the noise will come back. I suspect someone thing is loose.
I have attached an image of the light that I was referring to.
Thank you in advance!
davydliu is offline   Reply With Quote
Old 01-16-2022, 09:53 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
If it is a metal to metal vibration, I would try something easy and cheap first. Get a flat toothpick and nudge it between the fixturr and the ceiling. Turn on the heat pump and use your ears. Break off the toothpick with the help.of a.razor blade. Figure you'll have to.replace.the toothpick now and then. A piece of scotch tape would probably also work.
Old 01-16-2022, 11:02 PM   #3
Las Vegas , Nevada
It’s indeed metal to metal vibration. I can definitely try that.
Old 01-17-2022, 10:02 AM   #4
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Hi Davydliu, There are two parts to the fixture. If the center lens is buzzing, you can use a dull knife to pry the lens out and add something to insulate the glass from the metal or metal to metal, if the its the whole fixture, you can pull it away from the ceiling and put some tooth pick in there as Foiled mentioned. Here's a post describing fixture removal-disassembly for these ceiling fixtures. I got pretty good at pulling the lenses when I upgraded to LED lighting and added frost diffusers to all my ceiling fixtures. - Brad https://www.airforums.com/forums/f44...ml#post2006952
SuperTrouper is offline   Reply With Quote
Interior Finish? To remove or not to remove - can I use a heat gun stormbornSG Interior Restoration Forum 4 02-08-2017 03:31 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Noise from Water Pump on RV pump RICKBETTY Sprinter and B-van Forum 10 08-17-2016 09:43 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
