04-11-2021, 08:15 PM
2017 23' Flying Cloud
Austin
Water Heater working, but heavy Gas Odor
Hey Folks! New the the RV world and have discovered an issue with my 2017 23ft FC. While the Water Heater is producing hot water, there is an overwhelming Gas Odor coming into the trailer. With the trailer only 4 years old is it common for the the propane lines to go bad? Any help will be greatly appreciated!!!
04-11-2021, 09:06 PM
2017 28' International
Jim Falls
, Wisconsin
There is an LP gas sensor. It should go off if there is LP leaking.
Make sure the exhaust vent is clear on the outside. Open up the access to the water heater and inspect. May need to vacuum it out.
It could be your water heater is not getting a clean burn. In that case you may need to get it serviced.
My guess is that it isn’t a leak, because if it is a leak you would smell it when it wasn’t on.
04-11-2021, 09:07 PM
Austin
Thank you! I will check it out in the AM!
04-12-2021, 03:33 AM
Sag Harbor
, New York
Suggest shutting off both your propane tanks immediately, until you figure this out in a step-by-step process. Propane lines do not go bad generally, but you may have a dangerous leak situation IMO.
These "propane leak" search results may help you figure this out:
https://www.google.com/search?q=prop...=airforums.com
Many of the threads above are in the LP Gas etc. sub-forum here: https://www.airforums.com/forums/f287/
Welcome to the forum!
04-12-2021, 10:00 AM
2005 25' International CCD
Lilburn
, Georgia
Check to see if the propane tank is nearly empty. I have found the propane smells more then. Perhaps switch to the second tank. BUT as others have said check for leaks and perhaps cut off the propane for now.
04-12-2021, 10:40 AM
1977 31' Sovereign
Rochester
, WASHINGTON
Many of the threads above are in the LP Gas etc. sub-f:URL]https://www.airforums.com/forums/f287/[/URL]
Agreed.Dont wait for" heavy" smell of propane, to turn tank supply valves off immediately.Where it's coming from is not important at that point.
Stopping the flow is.
Airstream rodeo clown, it's my turn in the barrel 🤡
04-12-2021, 01:45 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Spend a few dollars and by a high quality hand held propane leak detector. You will like its sensitivity and ease of use. If its just an odor and not hydrocarbons (gas) it will not indicate any propane present.
guskmg
04-12-2021, 01:49 PM
Sag Harbor
, New York
Everything OK this morning?
04-12-2021, 02:09 PM
1977 31' Sovereign
Rochester
, WASHINGTON
04-13-2021, 07:18 AM
Sag Harbor
, New York
Good morning . . . all systems go?
04-13-2021, 07:20 AM
1977 31' Sovereign
Rochester
, WASHINGTON
04-13-2021, 07:59 AM
I'm In
, Kentucky
One time we had a burner on the gas stove that wasn't completely shut off. We kept smelling a garlic smell and the propane detector wasn't going off. We finally figured out what it was but it was overnight in a closed trailer. Lucky us.
You might check the fittings at the tanks and feed line for the water heater with a soapy solution.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
04-14-2021, 07:25 AM
Sag Harbor
, New York
Please update us.
Thanks.
04-16-2021, 09:32 AM
Hampden
, Maine
Just a year after we bought our AS there was a gas line connection leak. Using a soapy solution I easily found it. Since we are about 180 miles from the nearest dealer, I had it fixed at our nearest RV shop. Ordinarily, Ohio won't allow warranty work to be done other than at an AS dealer, EXCEPT in cases that are inherently life-threatening, such as a gas leak. So, turn off the gas and immediately get it repaired.
04-16-2021, 10:01 AM
Sag Harbor
, New York
Did you turn the gas off and find the leak?
04-16-2021, 10:28 AM
Hampden
, Maine
Not what I said...
04-16-2021, 10:44 AM
Sag Harbor
, New York
Originally Posted by airmaine
Not what I said...
Are you referring to my Post #15 which was not addressed to you, but to the OP [under his quote]?
04-25-2021, 10:32 AM
2020 22' Caravel
Chesterfield
, Missouri
Water heater
Please help.....no hot water. We have a 2020 23ft Caravel. Read everything snd still no hot water with electric or gas.
04-25-2021, 10:50 AM
2007 30' Classic S/O
Somewhere
, South Carolina
System is a on demand or tank type? Knowing what model helps a lot with diagnostics.
Has it ever worked correctly?
Is this the first time using it after winterization?
04-25-2021, 10:56 AM
Master of Universe
2008 25' Safari FB SE
Grand Junction
How many times has someone asked for immediate help (or in this case very immediate since propane leaks are very dangerous) and never lets us know what happened? Anyone check the news for fires or death in Airstreams in the last few days?
Gene
