Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Fresh Water Systems
Old 01-05-2018, 02:56 PM   #1
1976 31' Excella 500
Chappell Hill , Texas
What is this? & Where is Drain Valve
On my '76 Excella 31' center bath there is a clear hose hanging down from the corner of the fresh water tank cover. Is this the drain? I see a blue gate valve handle through this hole too but there is no access to it. Where is the valve access.
Also there is an electrical conduit coupling with some sort of rubber doodad up in it. Any idea what this is? Pics attached.Click image for larger version
ID:	301909Click image for larger version
tbashin is offline   Reply With Quote
Cut new access & replace drain valve on fresh water tank A W Warn Fresh Water Systems 16 03-31-2022 03:10 PM
Fresh Water Drain Valve & petcocks dnovosad Fresh Water Systems 8 01-16-2017 06:01 PM
fresh water drain valve/open & close billiards Fresh Water Systems 7 07-22-2009 06:10 PM
