Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Awnings
Old 07-16-2017, 11:44 AM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
Zip dee unlock thingy
I don't have the extension rod that unlocks the awning from the Argosy. It's a simple aluminum rod about 4 feet long, where can I get a replacement?
I'm in Seattle.
DanClick image for larger version
Dan S is offline   Reply With Quote
Old 07-16-2017, 11:59 AM   #2
Gregsch's Avatar
1979 24' Airstream Excella 24
Tipp City , Ohio
I would just call Zip Dee and have them UPS it to you. They are real good people to deal with.
Gregsch is offline   Reply With Quote
Old 07-16-2017, 01:14 PM   #3
1976 31' Sovereign
Oswego , Illinois
I never use rod scratched AS when slipped also can't get tight enough. Just do as I and others do use 2 step stool or as example one from amazon that is plastic will hold over 200 lbs. snaps open and close folds flat fits in closet. Can get wheel tight with out chance of coming loose plus much easier. You can also pur. alum. rod bend el on one end. some also use small fold flat ladder.
Old 07-16-2017, 01:36 PM   #4
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
I use a 5 gal bucket for a ladder to reach the front, entry steps will access the back one.
Some Airstream dealers carry the awning wand in stock.
"Chip Tank" is in Westwood Ca.
CDONA is offline   Reply With Quote
Old 07-16-2017, 02:39 PM   #5
centennialman's Avatar
2016 23' International
Centennial , Colorado
I bought a small, foldable aluminum step from Harbor Freight. It holds up 350 lbs and folds small enough to stow away in a small space. I use it to step on and get just enough height to unscrew or tighten the wheels that hold the awning in place by hand. Good luck!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 07-16-2017, 02:40 PM   #6
.... and here is the link:
https://www.harborfreight.com/step-s...orm-66911.html
Old 07-16-2017, 04:10 PM   #7
Hiwheel Joe's Avatar
1984 27' Sovereign
Central , Oklahoma
Puller
I too never use it for ulocking the round knob. I also use a ladder. I do use one for pulling out the awning strap. You can buy I think it is a king pin puller fron most local truck stops. Mine is aluminum, Airstream blue and does the job. I actually cut it a little shorter and re-bent the end so it fits in my storage behind the stove. It also has a handle on the end you hold.
Hiwheel Joe is offline   Reply With Quote
Old 07-17-2017, 06:04 AM   #8
1976 31' Sovereign
Oswego , Illinois
Smile
King pin puller is excellent for pulling strap to extend awning.
Old 07-17-2017, 06:26 AM   #9
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I'm in Seattle.
DanAttachment 289627
http://www.awningsbyzipdee.com/washington.html
Alan
Old 07-17-2017, 11:39 AM   #10
Clipper and Tug
elstunr's Avatar
2012 23' FB Flying Cloud
Colorado Springs , Colorado
Send a message via Skype™ to elstunr
I ordered mine from Amazon:
Ron & Michelle Elstun - Colorado Springs, Colorado
2012 Flying Cloud 23' - 2017 GMC Sierra 1500
https://sites.google.com/view/clipper-tug/home
elstunr is offline   Reply With Quote
Old 07-17-2017, 11:45 AM   #11
Rgentum's Avatar
2016 27' Flying Cloud
Olympia , Washington
The place in the Seattle area to buy metal goods in Online Metals, at the south end of the Ballard Bridge:
http://www.onlinemetals.com/merchant...195&top_cat=60
4 ft of 0.25 inch Al rod is all of $1.32.
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
Rgentum is offline   Reply With Quote
Old 07-17-2017, 12:18 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Never scratched Mjolnir using the ZipDee deploy tool. I rounded the sharp corners to help minimize potential.
Get a stout folding aluminum ladder.. like they mention above. Less likely to tip over.
One of the release tools are ok... but too heavy which may make it easier to damage trailer skin. But it is strong enough!!
Old 07-17-2017, 01:09 PM   #13
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The Zip Dee tool is the same tool as any awning rod.
Should be readily available at any RV dealer.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-17-2017, 01:53 PM   #14
2017 27' International
Lake Havasu City , Arizona
Interesting to read the comments about scratching the Airstream. The Zip-Dee pull rod that came with my 2017 Airstream has thick plastic coverings on both ends, so it can't scratch. Guess Zip-Dee got smart. :-)
Paprika is offline   Reply With Quote
Old 07-17-2017, 02:35 PM   #15
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
And when that wore out after a couple of years, I used red shrink wrap of the appropriate size,
George
gandttimes is offline   Reply With Quote
Old 07-17-2017, 04:11 PM   #16
1976 31' Sovereign
Oswego , Illinois
Smile
My rod also had plastic coating both ends but end to turn wheels came off slipped out of wheels made several long scratches both end when trying to to tighten so they will scratch and on my rod coating was only on bend not on tip, plus coating on big u en. I only use to pull strap use stool to turn wheels.
Old 07-17-2017, 04:19 PM   #17
m.hony's Avatar
2013 30' Classic
The red plastic thing falls off pretty quickly.
I still don't scratch the Airstream.
If I slip it hits somewhere on the awning arm or tube.
TAC #MS-10
Airforums #70955
Old 07-18-2017, 08:53 AM   #18
Hasbrouck Heights , New Jersey
Pick up 1/8 or 3/16 or even 1/4 aluminum rod from home Depot and put a right angle bend on one end and your done just make sure you have enough length
dk68 is offline   Reply With Quote
Old 09-01-2018, 01:52 PM   #19
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Any idea what material to use to replace broken red plastic tip on Awning Puller? Thanks!
Silvr_Bullet is offline   Reply With Quote
Old 09-01-2018, 07:57 PM   #20
Goal15's Avatar
Holly Lake Ranch , Texas
You can buy a rubber paint like substance that they coat ends of tools withat the big box hardware stores
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Zip Dee Lock/Unlock 345bill Awnings 14 04-22-2017 04:02 PM
Help! Door Won't Unlock! 66Overlander Doors & Locks 12 02-26-2013 10:38 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
Help, I can't unlock my door, Any ideas? rschulz Doors & Locks 20 12-18-2006 02:43 PM
