Originally Posted by DremStremer
When I removed the battery tray on my '70 Safari I saw this red wire underneath. One end was connected to the the rear compartment door frame but the other end was not connected to anything. In the picture, it's the thin red wire with blue connectors on each end. I assume it's a ground wire for something. Does anyone know what it should be connected to?
I can't tell from the picture, is the connector for the door at the top of the picture, not connected now? The other end that is just laying on the floor by the hole, that is the end under the battery tray, right?
It seems odd to me that a red wire was used for a ground, but then maybe that's all the PO had. [The connector color just indicates the size of the wire the connector is to be used for. It could be yellow, red or blue, for small wires.]
If the one end wasn't actually connected to anything on either end, I might guess that it was possibly power for a rear camera or maybe power to a radio in the AS so it would keep its memory. As a ground wire, I don't have any guesses, since it wasn't connected to the negative battery terminal and the connector is too small for that anyway.
In any event, I would just remove it. The PO didn't have it connected to anything so even he/she no longer needed it.
