'67 Overlander - where to place Jacks / Is it ok to jack the AS off the ground?
Dear Forum,
I would like to get taller/sturderier jacks so I can raise the AS and take most or all of weight off the tires and axles.
- the original jacks used now, keep most of the weight still on the tires/axles
However, our Airstream does not have any "spots" viewable as to where I can I should use even the jacks that came with Airstream. (Ive seen other older AS's with special areas for placing the AS's jacks.
1) Is it ok to just get larger jacks and use the same spots Im using now?
2) Is it ok to lift the AS tires at least partially off the ground (with better quality jacks)?
Thanks in advance!
Billy
