You still have too much weight on the springs. Try this.
Set the trailer level with what ever may be necessary under the tires and the tongue jack. Now lower the tongue about 1/2 in. Lower the rear stabilizers and then re-level the trailer with the tongue jack.
This should reduce the effects of the springs.
2004 Excursion 4x4
