Boxite, interesting indeed. I’ve read the Dometic OEM install manual many times and have not seen a reference to this part. As part of my recent refer fiasco on a trip to CA last year, I requested and rec a newer “oem” install. While it addresses insulation requirements and shows the lower horizontal fan as an option, there is no reference to this vent part that I remember. I’ll look at your link on a larger screen and reread both install manuals…again.
This part appears to be applicable to rm4601 which is a much larger refer system, but still worthy of investigation…I like the concept. While my fans primarily pull the, in theory, cooler air up from the bottom, thru the lower tubes, then out over the condensing fins, dealing with the much hotter burn tube air, gets pulled from the side and out with the rest. Maybe a vertical separation baffle??
I can’t disagree with you, but have never see this mentioned or spec’s on any AF threads.
Thanks for the info…I think
Certainly an option to think about.
Happy trails
