Originally Posted by OTRA15
Why do you put warm items in the fridge/freezer and get them colder? Isn't that a waste of energy, either propane or electric?
Why not put something already frozen in each compartment, and wait about an hour until each compartment registers the correct temp on a thermostat inside?
Seems simpler, less time-consuming and more energy efficient IMO.
Cheers,
Peter
Well...
if you put frozen things in the freezer... not much happens because the freezer doesn't have a thermostat...
so once the freezing section gets cold... the fluid pass by gravity to the lower compartment...and starts drawing heat out of it...
by putting frozen things in the freezer... you don't save much of any time or energy...
however,
PUtting frozen items in the refrig section would send a message to the theromostat that is located in the refrig section.... that the whole refrig is cold and so will shut down/cycle the refrig cooling unit...
and may not cool the whole refrig.. which is not what your wanting....
Thus you want to keep the refrig section above the thermostat setting so that the refrig won't cycle on and off... without touching the thermostat setting...
once the freezer section is frozen.. the fluid then absorbs no more heat... and stays about -5 or so... the fluid then moves down into the refrig section by gravity... and starts absorbing the heat their... once it gets to the 38 deg (about setting 3-4 on the thermostat) it will shut down the refrig.
You dont want to pre cool the refrig... section first... as the refrig doesn't work that way... if your going to get the max cooling effect and effecency..
so instead of just cooling the interior of the ref section.. and having it cycle down... you add a gallon water container... (drinkable when it cools down) and use it to keep the cycle going until the heat in the water is all absorbed...
if you put a frozen item... in the refrig... then the thermostat could shut down... and could leave the freezer section warmer.... because it thinks the freezer is as cold as its going to get and now the refrig section is cool enough...
So by using the water jug.... then it will stay on until the whole refrig now gets to the thermostat setting... with the freezer section as cold as its going to get...
So nope you want to put a jug of water in.. and allow it to keep the refrig from cycling while it cools down...
